Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 20th September 2004, 12:20 PM   #1
audioPT is offline audioPT  Portugal
Default Headphone amp
hi!
Does this topology will work well?
I've draw the basic schematic...
Pedro Martins
Old 20th September 2004, 12:45 PM   #2
Jennice is offline Jennice  Denmark
Why so many op-amp's in stead of a single buffer-chip with sufficient output power?
I suppose you consider the first op-amp (on the left side of the schematic) to act as a driver since it is connected differently than the rest? No need to use a "driver", if the input impedence is as high as a typical op-amp (don't know your particular chip).
Remember, headphones use fairly little power, so a lot of circuits should be able to do the trick.
Have you tried to simulate a circuit, which is basically a class-A buffer stage (voltage follower)? It seems to me that you're making life more complicated than it needs to be.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 20th September 2004, 10:08 PM   #3
The input impeadence to an op-amp is very high. The output impeadence is much lower. The only reason to use op-amps in this fasion is to put RC filters in between them to make an active filter network. You are attempting to lower the output impeadence of the op-amp circuit by parralelling the devices. There is a much easier way to amplify current. It is called an emitter follower circuit. (or source follower if you use a FET). Use one op-amp to drive the emitter follower stage which will drive the speaker or headphone.
Old 20th September 2004, 11:17 PM   #4
Why to do that " old way " ? Look at sites of peranders - there you will see modern headphone amps, buy one, build it and you will have not problems .
Another DAC + Headphone amp ghetto Digital Source 14 10th July 2008 05:02 PM
Using a headphone amp as a pre-amp? Basalt Solid State 4 19th November 2007 10:55 AM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 04:45 AM
Zen v4 headphone amp Rob M Headphone Systems 11 21st May 2003 01:58 AM
sym. Headphone amp Orgonom Headphone Systems 7 15th March 2003 08:28 PM
Page generated in 0.08694 seconds (72.77% PHP - 27.23% MySQL) with 10 queries
