Headphone Systems Everything to do with Headphones
Creating a headphone amp out of existing 2A3 amp
Old 28th July 2004, 05:32 AM   #1
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Default Creating a headphone amp out of existing 2A3 amp
hi guys,
what will it take to add headphone capability to a 2A3 SET amp? Is it going to be another transformer?
any information on how to do so will be much appreciated as usual.
cheers!
Old 28th July 2004, 09:21 AM   #2
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default Adding Headphones
You can just place a series resistor across the output of the amp to each earpiece.If you start at 470 ohms for the series resistor you can get the general idea. I am asuming these are the 200-600 ohm variety. If you are using the amplifier on low impeadance headphones then the resistor is even more important as you don't want to drive 2-4 watts directly into your ears.
Old 28th July 2004, 02:20 PM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Duh, or just don't run the thing at 2W. (Like it has the voltage output to do that into >50 ohms anyway.) They make these wonderful devices known as volume controls...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 29th July 2004, 12:08 AM   #4
ok, guys so i'll start with the resistor values recommended.
probably a switch too for amp/headamp operation.
cheers!
Old 29th July 2004, 08:50 AM   #5
follow up question -
shouldn't i be concerned about the "load" the OPT will see? that will be the series resistor + the headphone impedance, right?
that's far off from the 8 ohm load it normally sees as the speaker.
Old 29th July 2004, 08:59 AM   #6
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
"shouldn't i be concerned about the "load" the OPT will see?"
Right you are. I'd put an 8 ohm resistor across the output of each amp.
Frank
Old 29th July 2004, 03:10 PM   #7
Sch3mat1c's Avatar
Not necessary unless it has NFB and is prone to instability. A higher load will produce greater linearity in the triode, not like you'll notice a darned bit of distortion at .01% of maximum power output.
Tim
Old 30th July 2004, 12:10 AM   #8
no NFB guys
it's a JE Labs 2A3 using MagneQuest DS-025 OPT
so, as a safety precaution, shall i put the 8 ohm resistor across?
Old 30th July 2004, 01:06 AM   #9
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
There really is no need for it but you can try it for yourself.
Frank
Old 30th July 2004, 02:53 AM   #10
thanks guys
Creating a headphone amp out of existing 2A3 ampHide this!Advertise here!
Bi-amp Existing Speakers??? LLDeese Multi-Way 11 20th March 2007 04:05 AM
How to remove existing wax andy2 Multi-Way 2 26th May 2006 02:19 PM
PCB creating software Dr.H Parts 3 8th March 2005 08:43 PM
Creating new PCB Contacts bazooka Parts 2 30th January 2005 10:45 PM
Creating a wiki Mr Teal Everything Else 3 25th October 2004 09:59 PM
Copyright ©1999-2017 diyAudio
