Headphone Systems Everything to do with Headphones
best op amp for C'moy amp
Old 13th July 2018, 03:25 AM   #71
Stillhart is offline Stillhart
Originally Posted by xrk971 View Post
Unless you feel like re-inventing the wheel....
Use two 1688 and just get the nice board from AGDR that handles all the issues of unbalanced rails auto-protect, turn on thump protect relay, etc. 1688 makes a really nice amp. There are just a lot of ancillary supporting components needed to make it a user friendly amp - and might as well make something that sounds better than an O2.
OPA1688 Super CMOY, 2x 9V with real ground and headphone relay - PCBs
Sorry to hijack but I am working on a super basic CMoy as my first DIY project using the instructions here and I was wondering if I need to modify the circuit in any way if I want to use the 1688 instead of the recommended OPA2132PA.
EDIT - Oh I see it's SMB only and you need 2. I'll save that for my second go round... Please disregard.
Old 13th July 2018, 07:31 AM   #72
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
You can get an adapter board that lets it fit on DIP8 socket. The OPA1688 is a dual opamp.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th July 2018, 07:19 PM   #73
Got Foam?
xrk971's Avatar
Just an update that I am still using this mostly as a low noise preamp in any situation where I need to break a ground loop hum. But turns out to sound great and be useful as a general purpose Preamp. The rechargeable 9v batteries last about 3-4 days with average use. Very reasonable recharge rate. I will put his in a proper portable case and keep on hand as a tool for on the spot pre duties.
Old 20th July 2018, 03:51 PM   #74
Got Foam?
xrk971's Avatar
Here is a dual parallel buffer version of the above amp good for 150mA into 32ohms:
Cheap as Chips OPA1688 Low-THD Muscle Amp-opa1688-2parallel-buffer-schematic-png
Cheap as Chips OPA1688 Low-THD Muscle Amp-opa1688-2parallel-buffer-copper-eetch-layer-png
More info here:
best op amp for C'moy ampHide this!Advertise here!
