Headphone Systems Everything to do with Headphones
xrk971 Desktop Class A (DCA) Headphone Amp
Old 14th July 2018, 12:57 PM   #171
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
That converter requires minimum 9vdc to work properly I think. Try a higher voltage battery or you need a step up from 5v to 12v first.
Here’s the description.
Module name :250W boost constant current module
Module properties: non-isolated step-up module (BOOST)
Input voltage: DC8.5V-48V
Input current: 10A (MAX) exceeds 8A please enhance heat dissipation
Quiescent current: 10mA (12V liter 20V, the output voltage, the higher
the current will increase too quiet)
Output voltage: 10-50V continuously adjustable
Constant] range: 0.2-8A
You can try the MT3608 DC step up they are designed for lower voltage and max out at 24v out. They are finicky though and often blow up if you adjust the pot too quickly. Get several as $1.
Look what I found on AliExpress
MT3608 2A Max DC DC Step Up Power Module Booster Power Module for arduino Diy Kit-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Yesterday, 01:20 AM   #172
yourownbuzz is offline yourownbuzz
Oops. Without reading the description I just assumed it would work the same as the little 3608 ones. Still have a bunch of those from the pca - will give those a go! Not sure how such a tiny thing would hold up to the power dissipation
Old Yesterday, 07:58 AM   #173
Alright got it hooked up to a 3608 at 23.5v it's drawing 1.5A from a USB port. Seems to be holding up fine. However when I used it to step up to 12V to feed the other step up, it draws in excess of 3A @ 5V. Just have to wait for the 18650 battery holders to arrive to try with batteries
Old Yesterday, 12:45 PM   #174
Got Foam?
xrk971's Avatar
That’s strange that current goes that high. I would not run it at 3A it will blow up. Just use it to make 24v and its good for that as 1.2MHz switching grew is way above audio band.
Old Yesterday, 01:29 PM   #175
2A seems to be the max output so I guess it can draw however much it wants from the input? Not sure...it did heat up and then I pulled the plug on it. The step up wasn't damaged though.
Yep will leave it running straight off the 3608!
Also took the opportunity to swap in the 10k uF caps , even with the fat chisel it still takes some effort to solder suck the ground pins due to the larger sinking capacity of the board I guess.
xrk971 Desktop Class A (DCA) Headphone AmpHide this!Advertise here!
RJM Audio Sapphire Desktop Headphone Amplifier rjm Headphone Systems 1406 3rd July 2018 11:15 PM
xrk971 Pocket Class A Headamp GB xrk971 Group Buys 1843 16th June 2018 09:30 PM
xrk971 headphone amp vinodt1347 Swap Meet 1 19th January 2018 05:49 AM
iFi Micro iCan desktop headphone amp EndersShadow Swap Meet 2 26th December 2014 01:50 AM
Desktop headphone setup advice roadlesstraveled PC Based 2 15th November 2011 11:54 PM
