Headphone Systems Everything to do with Headphones
Simple High Performing Headphone Amp
Old 12th June 2018, 06:33 AM   #71
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by darbost View Post
Could this be a good preamp as well?
Certainly yes, with the ability to drive ANY impedance (even 8ohms) and low distortion, and what distortion there is when driven hard, is all second harmonic and monotonically descending higher orders 3rd and 4th...
It's also very good as preamp from standpoint of JFETs on input stage, so very low currents flow and pot makes no noises when adjusting volume.
As a DC-coupled amp, it is brutally revealing. Make sure your source has no DC or you might want an AC-coupled 4.7uF filmcap input coupler (toggle switch in/out).
I would imagine this amp driving a 10kohm load is a walk in the park.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th June 2018, 09:27 AM   #72
darbost is offline darbost  Indonesia
This means even for a low dc offset (less than 10mV, around 5mV) it will need a filmcap?
Old 12th June 2018, 07:47 PM   #73
badboygolf16v is offline badboygolf16v
Would this be on the board?
Old 12th June 2018, 08:20 PM   #74
Got Foam?
xrk971's Avatar
Not yet but letís see if JPS64 can add it.
Old 13th June 2018, 04:01 PM   #75
Got Foam?
xrk971's Avatar
The amp design is moving along. With more bells and whistles. Now with selectable Xfeed and optional input cap coupling. Built in single 12vdc to dual rail with DC step up and TI LDO 4uV regs and CRCRC.
Simple High Performance DC Coupled Class A HPA with sub PPM THD-fr4_complete_v1_top_6-xfeed-png
Old 19th June 2018, 02:00 PM   #76
Got Foam?
xrk971's Avatar
New DC-DC PSU with LDO, cap Mx, and CRCRC tested in hand etched prototype and works well.
More here:
Old 19th June 2018, 02:17 PM   #77
See ya later toroid!
Old 26th June 2018, 07:44 AM   #78
sarathssca is offline sarathssca  India
This one
I think here J3 and J4 needs to be matched (read somewhere)..
Do all the 4 jFets needs to be of same type or can we have J3 and J4 as BF862 as it is and use the cascode transistors with some other fFet or BJTs (bc5xx series )?
Old 26th June 2018, 10:56 AM   #79
Got Foam?
xrk971's Avatar
Yes, J3 and J4 need to be matched and J5 and J6 can be another type of JFET of similar Idss. Changing to BJT will require additional components I think and I have not tested it that way. You are welcome to try and mod it or suggest a BJT. However, the BF862 is so cheap that it doesn’t make any sense to.
Btw, measurements of the DC-DC PSU shows that it really does resemble a battery in low noise performance.
Old 26th June 2018, 11:47 AM   #80
Got Foam?
xrk971's Avatar
With a 10mV offset from the source and 20dB gain, you will have 100mV dc offset at the output. I hibk thatís probably an unacceptable level of offset for most headphones.
Simple High Performing Headphone AmpHide this!Advertise here!
A High-Quality, High-Power Headphone Amplifier gdan Headphone Systems 10 1st February 2016 01:08 PM
Simple Diy headphone amp thyristor44 Headphone Systems 13 19th September 2015 07:38 PM
simple SE headphone amp mrWagner Tubes / Valves 10 27th February 2015 09:00 PM
HPA-2 Headphone Amp Kit (High quality & High-end components) kawo Group Buys 20 17th February 2012 04:34 PM
Simple Headphone Amp Nico Ras Headphone Systems 69 8th August 2008 12:19 AM
