Headphone Systems Everything to do with Headphones
The REAL John Linsley Hood Headphone Amplifier
Old 24th June 2018, 10:37 AM   #101
edwtsui is offline edwtsui  Hong Kong
Hi Patrick,
What are the differences between the original design and your design??
Old 24th June 2018, 10:57 AM   #102
EUVL is offline EUVL  Europe
Read those posts I mentioned just now.
Patrick
xen-audio.com
Old 24th June 2018, 01:06 PM   #103
OK, it is SMD. Then, goodbye
Old 24th June 2018, 01:22 PM   #104
2SA970 / 2SC2240 are obsolete.
Their SMD equivalents 2SA1312 / 2SC3324 are not.
For a public project, one should use active components as much as possible.
Of course one can also try BC327 / 337.
But they are not as low noise.
Patrick
xen-audio.com
Old 9th July 2018, 11:03 AM   #105
GuidoR is offline GuidoR  Italy
GuidoR's Avatar
Originally Posted by EUVL View Post
As promised here the Gerber files.
The Bill of Material in Post #35 has the following changes for the XEN modified version :
R13,14 -> 470R
Cf1,2 -> leave open
Rz -> 5.1R
It is important that you only use 5mm standoffs to keep the legs of the output transistors short.
The original JLH version has yet to be tested, as mentioned before.
Happy building,
Patrick
HI Patrick, thank you for sharing your master work.
However, I can't read correctly the files, the traces don't match with the photos of the proto build. Could you kindly check? Many thanks
Guido
Old 17th July 2018, 05:34 PM   #106
Those Gertber files were exactly the ones used to make the PCBs in post #61.
Patrick
xen-audio.com
Old 19th July 2018, 11:47 AM   #107
passive420 is offline passive420  United Kingdom
Guido - I had a few boards made from Patricks Gerbers and they are fine, I can spare you a couple if just want a quick look. Will send a PM.
Old 26th July 2018, 10:11 AM   #108
chungtat is offline chungtat  Hong Kong
Is it possible to use 2SC5171/2SA1930 as output device without any modification?
Thanks.
Tat
Old 26th July 2018, 10:21 AM   #109
Yes, if you can still get them.
Obsolete at both Mouser and Digikey.
Patrick
xen-audio.com
Old 26th July 2018, 10:42 AM   #110
Note also that the hfe of those Toshiba devices begins to drop above 300mA.
Whereas the Sankens can go much higher.
So in addition to availability, the Sankens are also better devices.
Patrick
xen-audio.com
The REAL John Linsley Hood Headphone AmplifierHide this!Advertise here!
john linsley hood distortion analyser burbeck Equipment & Tools 6 3rd March 2017 06:42 PM
FS JOHN LINSLEY HOOD CLASS A AMPLIFIER (JLH) cucicu Swap Meet 0 29th October 2014 09:44 AM
John Linsley-Hood Revisited Alan Frobisher Solid State 1 31st July 2014 02:55 AM
John Linsley Hood 80W May 1989 djp150 Solid State 4 12th July 2011 08:10 PM
John Linsley Hood 80 or 100w amp djp150 Solid State 4 22nd April 2011 10:08 AM
