Headphone Systems Everything to do with Headphones
AT-HA-5000 schematic
Old 3rd February 2018, 04:09 PM   #11
Ricotjuh is offline Ricotjuh
I bought the kit. When I received it, I will share my experience
Just found some extra information:
Old 19th February 2018, 02:59 AM   #12
chillysalsa is offline chillysalsa  Canada
Is the 1K trim pot in the middle to set the bias?
If so, how does one set that correctly?
Old 26th February 2018, 01:28 PM   #13
I received 0.22 ohm / 5W emitter resistors instead of 0.1 ohm. Is this a problem? For the current through the FET?
Old 6th March 2018, 04:44 PM   #14
I have also another question, there are 3 different Silver Mica capacitors in the diagram. Namely 15pF, 27pF and 6pF. But I have received 16pF, 30pF and 5pF. Are these differences noticeable / audible? This also applies to some resistances. As an example I should have 24ohm but have received 22ohm. This also applies to some other values. Is it worthwhile to still order the right values or are these differences too negligible?
Old 6th March 2018, 10:35 PM   #15
keilau is offline keilau  United States
I am very eager to see your full evaluation of the kit and assessment of the finished headphone amplifier. Looking at the PCB and layout, it seems to me to be a clone of the Shanling PH100 which was a clone of the Technica HA5K. The PH100 has long been out of production. The seller also sells the complete package finished for $334.
Aliexpress.com : Buy GZLOZONE Finished Clone AT HA5000 Class A Headphone Amplifier from Reliable class a headphone amplifier suppliers on sep_store
Old 7th March 2018, 01:27 AM   #16
This GZLOZONE looks more true to the schematic in the second post. From a quick glance they have 3 trim pots, while the Breeze Audio clone has only 2. Which I am still not sure how to optimize.
Old 7th March 2018, 05:49 AM   #17
The 1K pot in the middle is to set the bias. Set it to the point so there is 200mA true the 0.1ohm resistor.
Old 7th March 2018, 02:24 PM   #18
Thanks very much!
Old 7th March 2018, 07:02 PM   #19
With the other potentiometer the balance; minimum DC on the output in idle state.
Old 7th March 2018, 11:58 PM   #20
You mean the other 1k trim by the input? Or the other 100 ohm trimmer near the input?
AT-HA-5000 schematicHide this!Advertise here!
MC PRE-AMP ETI 5000 SuperTuck Analogue Source 15 10th March 2014 06:35 PM
phonic xp 5000 schematic C3PO Solid State 17 8th June 2012 12:09 PM
Powersoft Digam 5000 and Q4002 Schematic b15075 Class D 0 8th December 2010 02:56 AM
APC SmartUPS 5000 schematic Johan_Ch Everything Else 3 21st January 2008 12:04 AM
Aurex (Toshiba) SA-5000 Schematic? manxam Solid State 0 30th December 2003 03:21 AM
