Headphone Systems Everything to do with Headphones
Aksa Lender HPA
Aksa Lender HPA
Old 20th January 2018, 02:24 PM   #21
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Aksa Lender HPA
It's a temperature effect on probably the output 2SA1837 or maybe even the LTP? But I took several measurements over about 30 min after the lid wad replaced. The temp of the output BJT was 97C with cover on and 67C with cover off. It looks like only the second harmonic distortion is reduced at higher temperatures. Or it could be that temperatures inside the cover are more homogenized and the LTPs are closer together in temp. As they are not thermally bonded, they may have differences when the lid is off. It's definitely a thermal effect though. THD went from 0.026% with lid off to 0.0063% with it on. The relative balance of H2 and H3 will make it sound sweeter with the lid off and more analytical with lid on. Adjustment of the LTP degeneration resistor values and also the R9 (make 68k or even 50k) can raise relative level of H2 vs H3.
Aksa Lender HPA-aksa-lender-hpa-130ma-bias-2-0vpp-43ohms-hp2760-temp-effect-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th January 2018, 08:14 PM   #22
Got Foam?
xrk971's Avatar
Aksa Lender HPA
Way to go Vunce!
Add a headphone jack and change a few resistors and you have a headphone amp.
Old 21st January 2018, 09:34 PM   #23
AKSA is offline AKSA  Australia
Brilliant work, Vunce!
You could easily put the preamp into a box three times smaller!
Nice use of a SMPS and elegant wiring on the selector and sources.
Some very serious caps in there.......
I never expected this preamp would be so good, but the drive on the voltage amp is very fast and I think it helps with the very low THD. XRK has championed this circuit and added his own versatility to it.
Thanks to XRK, J-P, and Vunce for making it reality.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 21st January 2018, 10:22 PM   #24
Max Headroom is online now Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by xrk971 View Post
It's a temperature effect.....
Ok, you have uncovered one instability/dependancy, good work.
Dan.
Old 26th March 2018, 10:20 PM   #25
badboygolf16v is offline badboygolf16v
I'm just building mine and have a few questions for X please...
- Is it necessary to increase C124/C134 to 1000uF as you have done in your HPA build?
- Is there any benefit from matching Q5s on the daughterboards?
- Should both C132 (or C1032) and C133 (or C1033) be installed? What are the options here?
- Should I build the CLC filter? I see it's not on your HPA build. If I use it would it affect the input voltage required?
Antony
Old 28th March 2018, 12:44 PM   #26
Got Foam?
xrk971's Avatar
Aksa Lender HPA
Yes, use as big of a value as you can fit here while still using a high quality brand (Elna Silmic II, Nichicon KA, Panasonic FG, etc). The values affects the bass extension depending on your phone impedance. For 50ohm phones, set the -3dB corner frequency to 2 octaves below where you want the amp to play bass flat to. Say you want flat to 20Hz, then 2 octaves below is 5Hz. Use equation Fc=1/(2 pi R C) and solve for C given impedance of phones in ohms and Fc of 5hz. So that gives 640uF. So 1000uF should be plenty.
Not really, as long as bias currents on both channels is within 5% you are fine.
It's your choice, but many people don't think a bypass cap on the inputs is a good idea as they say it smears the sound compared to even a plain electrolytic cap like an Elna Silmic II 10uF 35v cap. Use a high quality film cap here. Follow the same equation for setting the value. In this case, the input impedance is set by the 22k resistor to GND. So a 1uF cap here gives flat response to 29Hz. I have since changed this value to a 5.6uF film cap so my input bass extension is flat to 5Hz.
If you do not have a noise issue with the DC-DC converter adding noise to your amp, then not needed - however, it is a good idea to have it so that RF/EMI from the DC-DC converter in the amp gets radiated back out to your mains or environment outside of the box. I have used 47uF and 1mH here with a 51R parallel to the 1mH for stability.
Antony
As the TH and SMT MELF and SMT 0805/1206 boards have different designators, let's assume you have the TH one, as that is assumed to be needed for the 2SA1837's to be used.
Main board (MB) schematic:
Old 28th March 2018, 04:14 PM   #27
Thanks for the detailed reply X. The examples are very useful, as I'm lacking basic electronics knowledge. I've just bought The Art Of Electronics, so I'll read up on the filter section with this schematic in mind.
Old 18th May 2018, 08:49 AM   #28
yourownbuzz is offline yourownbuzz
where does one get the 2SA1837 nowadays?
I had a look on ebay but I guess anything from china and surrounds are suspect. what about ones from the UK? (5X 2SA1837 High Frequency/HF/RF PNP Amplifier Transistor PACK OF 5 | eBay)
Old 18th May 2018, 09:10 AM   #29
Got Foam?
xrk971's Avatar
Aksa Lender HPA
I bought the last remaining batch of genuine Toshiba from Mouser a year ago. They are becoming rare... I can sell you one when you order the Aksa Lender pre MB's. 2SA1837 are $10/pair.
The photo in that link is all wrong. The 2SA1837 are all black epoxy covered, no metal tab.
Old 18th May 2018, 03:33 PM   #30
tonza75 is offline tonza75  Europe
You could try 2SA1837LB-TF3T at 2SA1837LB-TF3T - Power Transistor -230V -1A
Aksa Lender HPAHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 718 21st July 2018 06:59 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 399 26th June 2018 10:26 PM
AKSA 100 N+ the hum the hum! Erskib AKSA 18 10th February 2015 02:03 AM
The most linear stage for large voltage swings - Lender's Circuit tiefbassuebertr Solid State 47 26th September 2013 04:54 PM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
