Headphone Systems Everything to do with Headphones
Anyone tried to build LME49600 Headphone Amplifier Evaluation Board??
Old 13th January 2018, 09:11 AM   #11
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You want specific components? If so then try a TDK SLF7045T-102 (1mH) and a Nichicon HZ 1000uF/16V. This combination does a great job in my circuits.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 13th January 2018, 09:51 AM   #12
edwtsui is offline edwtsui  Hong Kong
No. Sorry.
I mean the schematic example of the LC filter. Or simply the schematic of power supply circuit
Old 13th January 2018, 10:13 AM   #13
abraxalito's Avatar
Here's the schematic, its not that complicated - you'll normally need two of these, one for each rail.
On the left that's your input (shown as a voltage source) which is the LME supply, the output to the opamp is to the right.
Old 13th January 2018, 02:03 PM   #14
Thanks for your help.
In my design, I planned to use two LME49710 and LME49600/BUF634 (For one channel). One LME49710 serve as voltage gain and the other one serve as DC servo, so I need to separate each one with LC filter as the schematic attached??
Old 13th January 2018, 05:03 PM   #15
scafas is offline scafas  Italy
Default info pcb
if interest , i have some of this pcb to buid a lm49600 headamp.
the schematic is take from original datasheet and i have add a dual voltage psu on board with 7815 and 7915.
pcb is 100x100 mm. , double layer with a stereo pot in like 2x50kohm alps.
Old 13th January 2018, 11:10 PM   #16
abraxalito's Avatar
No, you'll only need two filters (so two Ls, two Cs) unless you're adopting separate L,R channel construction (when you'll need four). Both the LME49710 on a single channel can be powered on the same rails as their outputs are barely loaded.
On the schematic you've shown you only need L1 and L4 and C1,C4. L2,L5,L3,L6 are replaced with wires and C2,C3,C5,C6 are omitted.
Anyone tried to build LME49600 Headphone Amplifier Evaluation Board??Hide this!Advertise here!
LME49600 based headphone amplifier jpak Swap Meet 2 19th January 2015 09:16 PM
Lme49600 headphone amp Dr. Popo Chip Amps 67 12th April 2013 12:55 AM
FS: LME49600/ LME49710HA headphone amplifier mravlca Swap Meet 3 9th June 2011 06:05 PM
FS: Tripath EB-TA4100 4-Channel Class-T Amplifier Evaluation Board ralphs99 Swap Meet 7 16th May 2009 09:33 AM
FS: Microsemi LX1722 Class-D amplifier evaluation board. ralphs99 Swap Meet 2 17th March 2009 11:19 PM
