Headphone Systems Everything to do with Headphones
optical illusion amplifier
Old 13th December 2017, 07:10 PM   #1
oceanpeak is offline oceanpeak  United States
Default optical illusion amplifier
optical illusion amplifier, 1 op amp, jfet input, incomplete
Old 13th December 2017, 10:49 PM   #2
adason is offline adason  United States
adason's Avatar
Great idea, congrats!
What is it?
Old 13th December 2017, 11:23 PM   #3
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
It is an optical illusion amplifier.
It amplifies optical illusions.
Old 18th December 2017, 04:00 PM   #4
Just assume for a few moments that Vds is the supply rail that is an ideal voltage source, between saturation and threshold, and measurer that power supply already.
Old 18th December 2017, 04:03 PM   #5
You all either want to see it complete so you can build and kopi it or have someone hold your hand when you can't read a single graph I'm not going to be much help.
Old 18th December 2017, 04:06 PM   #6
PS you've been selling redistributed mp3 streaming so long your whole world could be X1 Mbps and you just realized pcm is archaic.
Old 18th December 2017, 04:09 PM   #7
And your whole world best IPO that didn't get shorted yet has some new drug war jingles dropping every week. You the best
Old 24th December 2017, 04:49 PM   #8
I made a mistake on what I posted. I forgot to think about a current mode voltage amplifier because I was so confused by your digital biphase signals that you programed into 0s and 1s to remember that level shifting is what op amps were designed to do which is digital which is still asymptotic analog. Update two op amps level shifted just like a cxlr 4150.
Old 24th December 2017, 10:51 PM   #9
PRR is offline PRR  United States
PRR's Avatar
I assume you use a base plate of prefabulated aluminite, surmounted by a malleable logarithmic casing in such a way that the two main spurving bearings are in a direct line with the pentametric fan, which is six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling is effectively prevented. The main winding should be of the normal lotus-o-delta type placed in panendermic semi-bovoid slots in the stator, every seventh conductor connected by a nonreversible tremie pipe to the differential girdlespring on the "up" end of the grammeters.
Old 25th December 2017, 12:14 AM   #10
voltwide is offline voltwide  Ireland
It's time to swap the drug dealer
optical illusion amplifierHide this!Advertise here!
Measuring & modeling 4N35 optoisolators for Optical Bias amplifier uses Mark Johnson Solid State 14 30th December 2016 10:36 PM
Trying to find the name and examples of an optical illusion. Mooly The Lounge 48 7th October 2016 08:20 AM
line to optical ---> optical to analog dirtbiker1824 Digital Line Level 6 15th October 2014 06:17 PM
illusion audio ? MyNameIsJake Car Audio 11 24th March 2011 11:07 PM
Illusion Drivers one_happy_hippy Multi-Way 3 22nd February 2004 12:05 AM
