Headphone Systems Everything to do with Headphones
Mosfet class A headphone amplifier
Old 10th December 2017, 09:06 AM   #1
sevenup2278 is offline sevenup2278  Netherlands
Default Mosfet class A headphone amplifier
I have been working on a mosfet buffered class A headphone amplifier.
Onboard power supply
Bridge rectifier and C-R-C smoothing
Separate voltage regulators for both channels (lm317/lm337)
Single opamp for voltage amplification
Class A Mosfet output buffer
LM317 Constant Current Source for bias
Heatsink can be mounted on the ridge of the PCB, making it one unit.
Done a test with LF356 opamp and IRF510 mosfet, works great.
Now working on the PCB layout, should fit on a 10x10cm board.
Old 10th December 2017, 01:51 PM   #2
Schematic for 1 channel
Old 10th December 2017, 02:02 PM   #3
Mooly's Avatar
Looks good
A couple of thoughts... a FET input opamp doesn't need R1, also you can increase R2 and decrease C3 and so use a small film cap. There is no noise penalty as the resistor is shunted by the impedance of the driving source component. 470k and 0.47uF are standard sort of values and would give an LF response way below anything useful for headphones.
An input RF filter might be a good idea.
Although there should be no offset issues with a FET opamp, you should consider returning the internal gain to unity at DC (which means a cap in the feedback return).
Old 10th December 2017, 02:16 PM   #4
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
After observing that current source bias resistor R4 will dissipate 230 mW, I would be tempted to stuff and solder a resistor rated for 2 watts continuous dissipation, such as (this) 2W resistor whose dimensions are only 3.9mm x 10mm.
I think I would also include a Zobel network on the output, which loads the amplifier and prevents oscillation, when no headphones are plugged in.
Finally, I personally prefer a 2C+1R snubber across the transformer secondary, instead of 4 capacitors across all 4 diodes in the bridge rectifier (as shown on the PCB layout). I myself prefer to control the damping of the transformer secondary circuit, and indeed I deliberately choose to overdamp the secondary (zeta >= 1.0) to guarantee the complete absence of ringing. There is a .pdf document called Quasimodo here on the DIYA website, which discusses my snubber preferences at length. But, I hasten to point out, these are my preferences. Other design engineers have their own preferred approaches, of course.
Old 10th December 2017, 02:22 PM   #5
Originally Posted by Mooly View Post
Looks good
Thanks for the input
I have made some changes, however not sure about the RF input filtering. Is this what you mean?
Old 10th December 2017, 02:24 PM   #6
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
You need a RF filter at the input.
R1=1kOhm
C=470pF FKP/MKP
Old 10th December 2017, 03:03 PM   #7
R1=1kOhm
C=470pF FKP/MKP
Ok, so it is a series R / parallel C lowpass filter.
Would this be a good capacitor for this purpose?
https://www.eoo-bv.nl/stabiele-hq-36...pf-630v-2.html
Old 10th December 2017, 03:14 PM   #8
Pitch for the CCS resistor is bigger then the rest (12.5mm) so I should be able to fit this resistor MF 6,8 Ω 2W 5% MO
I have added a zobel to the output, is 100n / 10Ohm ok?
Old 10th December 2017, 03:32 PM   #9
MKP 470pF
Yes, this one is OK.
Do you have a power supply unit?
Old 10th December 2017, 05:03 PM   #10
ammel68 is offline ammel68  United States
Banned
R1=1kOhm
C=470pF FKP/MKP
Why is a MKP capacitor necessary for a RF filter?
Mosfet class A headphone amplifierHide this!Advertise here!
All MOSFET Class A headphone amplifier kacernator Pass Labs 4 19th September 2017 02:46 PM
Class-A Mosfet Headphone Amplifier jhorapalok Headphone Systems 7 16th January 2016 07:50 PM
Simplistic Class A MOSFET Headphone w Feedback: have I got my values right? monty78pig Headphone Systems 11 6th November 2012 03:56 AM
Class A mosfet headphone amplifier. How does it look? Plecto Headphone Systems 1 6th November 2012 03:11 AM
my Class-A MOSFET headphone amp davygrvy Headphone Systems 28 18th October 2011 06:42 AM
