Headphone Systems Everything to do with Headphones
Mosfet class A headphone amplifier
Old 10th December 2017, 06:12 PM   #11
Buzzy is offline Buzzy  Singapore
The lt1086 and lm317 are positive voltage regulators. Will it work when the out pin is connected to negative supply ?
Old 10th December 2017, 06:24 PM   #12
sevenup2278 is offline sevenup2278  Netherlands
Sure, it is only relative. Output should be lower then input.
Old 10th December 2017, 06:40 PM   #13
Mooly's Avatar
The RF filter looks OK. 470pF is suitable to use with a 1k. Any decent small film cap is fine, but not a ceramic disc type.
Old 10th December 2017, 07:08 PM   #14
tomchr is offline tomchr  Canada
tomchr's Avatar
I'd put 470 kΩ to ground on the "outside" of the input coupling cap to prevent the cap from charging when the input is disconnected.
Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 10th December 2017, 07:35 PM   #15
BesPav is online now BesPav  Russian Federation
Originally Posted by sevenup2278 View Post
Schematic
First, change connection to inverting.
Second, read this thoroughly:
http://www.ti.com/lit/an/slyt174/slyt174.pdf
Use circuit B with something like AD8067, LT1222, LM7171, THS4021.
Third, drop linear regs, use passive CRC with 7-10 Ohms inline. Decouple opamp locally closer than 5 mm, higher than 10 nF NP0.
Fourth, drop MOSFET, use medium power BJT this will shift opampís output stage slightly with A-class guarantee and decrease load capacitance.
Fifth, do not use toroid trafo for supply, only sectioned El.
Eight, put little common mode choke at the input.
Seventh, put common mode choke at the output.
Old 10th December 2017, 07:43 PM   #16
Tom
Hi Tom,
Is this resistor still needed whene there is a potmeter on the input?
Old 10th December 2017, 08:38 PM   #17
The idea was to make a mosfet output stage and use fet input opamp. I will stick with that idea for the moment.
Old 10th December 2017, 11:01 PM   #18
tomchr's Avatar
If you have a volume pot soldered to the input of the amp board, the volume pot will drain the cap.
Tom
Old 10th December 2017, 11:04 PM   #19
tomchr's Avatar
That will greatly increase the supply impedance compared to the regulated supply. It will also result in worse filtering, in particular when the parasitics of the supply caps are factored in.
As for inverting vs non-inverting: I'm assuming you're concerned about common-mode distortion. That's not really a thing anymore with modern opamps. I'm sure you can find one opamp out there somewhere that shows common-mode distortion, but amps like the LME49710, OPA1611, etc. perform better non-inverting than inverting, at least for buffer applications, due to the 6 dB higher loop gain of the non-inverting configuration.
Tom
Old 11th December 2017, 12:54 AM   #20
PRR is offline PRR  United States
PRR's Avatar
Is Tori still around??
I don't know why you would want +/-15V and 200mA for any headphone. Well, maybe this week, we are in for a cold spell.
When I looked at this, a long time ago, I could not avoid a ~~10MHz instability without the added C5-R4 network to decouple the NFB above 150KHz.
Mosfet class A headphone amplifierHide this!Advertise here!
All MOSFET Class A headphone amplifier kacernator Pass Labs 4 19th September 2017 03:46 PM
Class-A Mosfet Headphone Amplifier jhorapalok Headphone Systems 7 16th January 2016 08:50 PM
Simplistic Class A MOSFET Headphone w Feedback: have I got my values right? monty78pig Headphone Systems 11 6th November 2012 04:56 AM
Class A mosfet headphone amplifier. How does it look? Plecto Headphone Systems 1 6th November 2012 04:11 AM
my Class-A MOSFET headphone amp davygrvy Headphone Systems 28 18th October 2011 07:42 AM
