Headphone Systems Everything to do with Headphones
HEXFET headphone amp !?
Old 5th December 2017, 02:16 PM   #21
xXBrunoXx is offline xXBrunoXx
wow , Im such a noob. Than you sir !
Old 5th December 2017, 02:21 PM   #22
Mooly's Avatar
No problem At least in LT it doesn't burn a hole in the screen dissipating several kilowatts power
So now you need to make it all work on a much lower voltage, and that is where it gets really really difficult. I doubt you would get a satisfactory result on just 5 volts (-/+2.5 volts), even if you changed the topology around and tried to go for a rail to rail output stage.
Old 5th December 2017, 03:27 PM   #23
I can't really understand why they used such little power fet's in this design ( this board was from an 5.1 DVD home theatre, which sounded pretty good )
As I can see , were they used 2 of them bridged per channel not in parralell ? ( max rattings 2w per ic ) so almost 4w per channel ? wow..why didn't they use ic' power amplifiers like TDA or something instead of this ? .
I got a few, I can parralel them i guess .
Old 5th December 2017, 05:51 PM   #24
Mooly's Avatar
Could they have been running in Class D ? That would be far more applicable for low loss FET's.
Old 5th December 2017, 11:31 PM   #25
PRR is offline PRR  United States
PRR's Avatar
I was thinking they have to be "mute" devices, not amplifiers.
Old 6th December 2017, 09:12 AM   #26
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by xXBrunoXx View Post
That step-up converter would be great and cheap , but not avaiable where I live. Im from Romania.
Aliexpress or eBay doesn't ship to Romania?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 7th December 2017, 05:17 PM   #27
eBay ships but transport price is pretty high.
Old 7th December 2017, 05:31 PM   #28
Got Foam?
xrk971's Avatar
IRF7319 are good for 5amp ea and double N ch and P ch devices. So good for 10amps in parallel and 30v. Pretty good size punch there in my book. Discrete MOSFETs in general have better bass extension and authority than a chip amp.
HEXFET headphone amp !?Hide this!Advertise here!
Please help troubleshoot my HEXFET amplifier Ranchu32 Solid State 13 31st January 2015 11:46 AM
HEXFET amp silverchris Solid State 9 31st October 2006 03:38 PM
Hexfet as diodes? millwood Solid State 16 11th November 2003 11:56 PM
3rd generiation HEXFET vs. 5th generation HEXFET DarkOne Solid State 3 12th April 2002 07:51 PM
HexFet 60 Ychnaval Solid State 4 10th December 2001 07:16 AM
