Headphone Systems Everything to do with Headphones
HEXFET headphone amp !?
Old 5th December 2017, 02:21 AM   #11
PRR is offline PRR  United States
PRR's Avatar
Yes, they need 4V drive... for 20 Amps flow!! We don't need to hit them that hard. Headphones don't need even 300mA, 0.3A.
The 1V @ 250uA is not directly useful, no. But this and the 4V @ 20A define a curve that we want to find mid-points on.
The total range 250uA to 20A crosses at least two MOSFET modes, and we can't know the exact curve of the line. But it will be roughly straight, with a bend, plotted on the log/lin paper the spec-sheet uses. I've attached my guess. I think the headphone current range is 1.5V-2V. This is very approximate, and the bias MUST be tuned to the actual devices.
This is not a "bad" voltage for a 12V headphone amp. However the next question is to fill in the rest of the plan. Which is really a request to give free design services so that some very specific "free" MOSFETs can be used. Which is considerable thinking time, and more time to write/draw it up.
Old 5th December 2017, 12:47 PM   #12
xXBrunoXx is offline xXBrunoXx
That step-up converter would be great and cheap , but not avaiable where I live. Im from Romania.
Old 5th December 2017, 12:50 PM   #13
I've tried to make myself an dc-dc step up From 5v by 555 and irfz44n but failed.
Old 5th December 2017, 12:55 PM   #14
If I can't really use these hexfet's , easiest way would be to use some op amp + BD139-140 by rod elliot's headphone amp schematic on + - 2.5v , 0.6v for the transistors , would I get at least 1v - 1.5v output on 5v supply ?
Since my phone/ mp3 player doesnt have the "omph" for my headphones ( 32ohm ) I want a small portable headphone amp ( 5v would be great as I have one external battery 5v 2amp output ( 6amp capacity )
Old 5th December 2017, 01:42 PM   #15
Weird thing , I've tired some schematics in LTSpice to " play " with mosfets, see their Vgs , how much to open them, etc. Every mosfet even at 4 - 6v Vgs it draws a few 5-10 - 30 amps from the rails, this is weird .
Even this one only with one 1n4148 across gates I get 11v Vgs and 88A from rails. Even with 4-0-4 V RAILS I get 3amps .. Something wrong with my LTSpice maybe...?
Old 5th December 2017, 01:47 PM   #16
Mooly's Avatar
Your 5 volt requirement is the killer for all these.
Why not have a look at something like the TDA2822 chip which operates down to a couple of volts. Fig 1 in the data sheet is all that is needed. Add a volume control and possibly a low value series feed resistor to the headphones and your done.
http://www.st.com/content/ccc/resour...CD00000134.pdf
Old 5th December 2017, 01:50 PM   #17
Mooly's Avatar
If you post your .asc file I'll take a quick look.
Old 5th December 2017, 01:54 PM   #18
Here, Thank you .
Old 5th December 2017, 01:59 PM   #19
Mooly's Avatar
M2 is your problem Have a close look.
Old 5th December 2017, 02:05 PM   #20
Mooly's Avatar
Its upside down.
HEXFET headphone amp !?Hide this!Advertise here!
Please help troubleshoot my HEXFET amplifier Ranchu32 Solid State 13 31st January 2015 11:46 AM
HEXFET amp silverchris Solid State 9 31st October 2006 03:38 PM
Hexfet as diodes? millwood Solid State 16 11th November 2003 11:56 PM
3rd generiation HEXFET vs. 5th generation HEXFET DarkOne Solid State 3 12th April 2002 07:51 PM
HexFet 60 Ychnaval Solid State 4 10th December 2001 07:16 AM
