Headphone Systems Everything to do with Headphones
Critique my PCB! Headphone amplifier
Old 4th December 2017, 02:40 PM   #31
abza is offline abza  South Africa
abza's Avatar
Quick question regarding the decoupling capacitors: Are the values I've got ideal?
  • 100uF electrolytics & 22uF X7Rs for the buffers
  • 22uF X7Rs for the opamp
I know @00940 mentioned that the 22uF X7Rs, given capacitance fluctuation due to voltage changes, would be less than ideal... and even 10uF caps would be better there.
I also read in this Analog Devices article that they recommend a very small (0.01uF - 0.1uF) close to the device and a larger (10uF - 100uF) cap further away, per rail.
While @JPS64 uses 0.1uF, 2.2uF and 100uF for each rail in his schematic.
Which values and types should I be using, assuming my current selection is less than ideal?
Old 4th December 2017, 03:29 PM   #32
OlegSh is offline OlegSh
I would use 0.1uF and 100uF, assuming that electrolytic capacitor is not much further than an inch from the IC.
Critique my PCB! Headphone amplifierHide this!Advertise here!
AB amplifier is oscillating. seeking critique jlny Solid State 56 13th February 2016 02:06 PM
Critique this noninverting opamp buffer/amplifier please? Almost time to build... audiovisceral Analog Line Level 87 2nd March 2015 05:25 PM
Headphone Impedance and headphone amplifier TheGimp Tubes / Valves 89 3rd May 2014 01:46 PM
Headphone amplifier audiofan Headphone Systems 5 3rd March 2006 03:43 PM
Please critique my Class A amplifier!! AudioGeek Solid State 2 28th July 2004 08:02 PM
