Hello folks.
I am currently designing an small Class A amplifier for my 32 ohm headphones but i am looking for a bit of experience regarding Transistor choice. Currently for output i am running BD135/139 and BC847 for preamp but i am not sure if the BC847 would be a good choice. The preamp does not use alot of power so almost every transistor should work. Was thinking about running MMBT3904 but i am trying to go for some transistors i could have at the place i'm working at.
To the info it is a NPN transistor.
Stefan
Stefan
.....almost every transistor should work. ....
Exactly what you say. If the circuit is good, and the transistors are not burning-up, "almost every transistor should work".
We would need to know a LOT more about your design to comment intelligently on transistor choice.
Mt last headphone amp, I just grabbed plastic PN3055 and PN2955- the all-purpose power devices. Working about 2% of their ability, but about as cheap as any other. The one before was a single TIP120-- again loafing and cheap.
