Headphone Systems Everything to do with Headphones
Mixed metals headphone cable
Old 4th November 2017, 04:26 AM   #11
PRR is offline PRR  United States
PRR's Avatar
All my life, car brake lines were steel.
Now my mechanic has sold me Copper-Nickel brake lines (at 3X the price).
Some research says that steel lines rust (I know), that Cu-Ni lines were identified as better in 1969, but most car makers clung to steel for cost.
I'll find out if my car sounds better with mixed metals lines.
Old 4th November 2017, 04:30 AM   #12
tizman is online now tizman  Canada
Please do. Inquiring minds need to know....
Old 9th November 2017, 06:02 AM   #13
DualTriode is offline DualTriode  United States
Hello,
A couple of years ago I made a Single End Balanced output headphone amplifier and a set of balanced cables for my HD600’s. The SET transformers are custom balanced push / pull with a center tap ground.
The cables are two silver plated Teflon insulated conductors with shielding. The cable is surplus and came from apexjr.com. Each channel is a monoblock. The cables connect separately to each amplifier with mini-XLR’s. Unlike the original HD600 cables there is not a common ground conductor, there is no cross talk caused by a common ground conductor.
There is no magic in the silver.
DT
Old 9th November 2017, 06:51 AM   #14
DualTriode: I have some of the wire you are describing. The one I have has two 24 AWG stranded silver plated copper conductors, each with its own Teflon sheath, inside a shield that is also silver plated copper. These are all contained in another exterior Teflon sheath. I usually use it to wire from the inputs of tube amps to the pre amp tube. It's convenient because I can ground the shield too. This would make a very quick, shielded interconnect cable or a headphone cable as you applied it. It's great wire.
Mixed metals headphone cableHide this!Advertise here!
GAMECOM Headphone Cable bwilliams Headphone Systems 0 24th May 2014 12:12 AM
Headphone cable wiring Cue Rios Headphone Systems 7 12th July 2012 06:55 PM
Headphone Cable coacharnold Headphone Systems 19 10th January 2012 08:28 PM
Headphone amp with mixed-in telephone audio krfjr1965 Solid State 3 10th March 2010 03:50 PM
