Headphone Systems Everything to do with Headphones
Chinese hv1 eBay diy kit relay problem
Old 7th October 2017, 02:57 PM   #1
Lloydy304 is offline Lloydy304
Default Chinese hv1 eBay diy kit relay problem
Just put together this kit and it sounds awesome with my akg k712s.
the problem is after 10min of play the protection relay clicks off on repetetly.
The spec sheet says this is dual 12-15v 30va amp. I had a spare toroidal transformer lying around rated at x2 15v and 100va.
The voltage reading is 18v off load and 17.5v when amp is powered. The amp is using 0.25amp per 15v load.
When blowing on the transistor heatsinks the relay stops clicking.
also when plugging in my ipod the relay cuts the headphones off when upping the volume past a quarter turn this is not the case when connected to my pc soundcard
So my question is should I upgrade the heatsink or downgrade the transformer to a 12v 30va or could there be another issue. All components are fitted correctly.
kit is based on A1
Video of the problem
YouTube
Old 7th October 2017, 04:06 PM   #2
Pcb
https://img.alicdn.com/imgextra/i4/1...1816774652.jpg
Old 7th October 2017, 04:12 PM   #3
Sellers Discription:
Main materials:
Original ST33078N dual op amp, STDB139-140 power transistor.
Panasonic FK Series main smoothing capacitor
1/4W 1% precision metal film resistors
AUDIOPHILE MKP 4U7 400V 3% precision tinfoil capacitance
Omron G2R - 2 12V Relay 700MV Protection circuit,7 seconds delay connect function.
Old 7th October 2017, 04:32 PM   #4
phase is offline phase  United States
My headphone amp runs warmer than Id like, so I use a 75mm, 12v fan, running at 5v to lower the temp.
Old 7th October 2017, 04:40 PM   #5
im planning o putting it into an aluminium case so i will end up fixing the trasitors to the case, but the transistors are hot atm but you can touch them.
Old 7th October 2017, 10:58 PM   #6
Transformer setup
Old 9th October 2017, 05:50 PM   #7
Bump
Old 9th October 2017, 05:52 PM   #8
HumbleDeer is offline HumbleDeer  Belgium
HumbleDeer's Avatar
If blowing on the heatsinks makes it stop, it's clear that the transistors have reached their maximum functioning junction temperature. Past that, they become unpredictable. That's how MOSFET's burn out.
Chinese hv1 eBay diy kit relay problemHide this!Advertise here!
Modi 2 Uber or a Chinese DAC Off Ebay? SRMcGee Digital Line Level 23 17th January 2017 11:52 AM
Chinese WM8740 DAC from eBay mlihl Digital Source 0 20th June 2014 12:09 PM
Cheap Chinese Ebay Amps chris12345 Tubes / Valves 10 10th November 2011 02:21 AM
Chinese Kits EBAY tatolovera Chip Amps 5 22nd July 2011 07:05 PM
ready-to-use Ebay Chinese DACs jarthel Digital Line Level 0 6th June 2009 12:40 AM
