Headphone Systems Everything to do with Headphones
The Pioneer Super Linear Circuit
Old 5th December 2017, 12:43 PM   #81
EUVL is offline EUVL  Europe
A copy-and-paste error in Appendix 2.
R15~20 are missing.
They should be the same as those in Appendix 1.
Well spotted.
Sorry for that,
Patrick
PS Will update revision in a day or two.
xen-audio.com
Old 5th December 2017, 10:23 PM   #82
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Hi. Other typo error, Passive crossfeed section, BOM, both capacitors should be ECHU series I think because EUHU doesn't exist...
Old 6th December 2017, 03:07 AM   #83
Correct and well spotted.
I better wait a few more days before update, in case you can find more.
Patrick
xen-audio.com
Old 8th December 2017, 06:19 PM   #84
Algar_emi's Avatar
I would suggest that you add the Passive crossfeed and Protection pcb schematic into the document. They are the only schematics missing. Thanks
SB
Old 9th December 2017, 07:05 AM   #85
http://www.diyaudio.com/forums/group...ml#post4759695
Patrick
xen-audio.com
Old 11th December 2017, 11:43 AM   #86
Morde is offline Morde  Finland
Yesterday I populated the regulator boards and I measured the output voltages with no load while feeding the input with two 9 V batteries in series. I got the following results:
+Vout1 = 14.99 V
+Vout2 = 14.97 V
-Vout1 = -15.05 V
-Vout2 = -14.95 V
I suppose these values are good enough so I don't need to adjust the voltages with R1?
My finished headphone amp projects: 1, 2, 3, 4, 5, 6, 7
Old 11th December 2017, 12:35 PM   #87
Yes, especially if you are using either the CCS bias or the DC servo.
Patrick
xen-audio.com
Old 14th December 2017, 06:31 AM   #88
Yet one more mistake in the document.
In the BoM, you will need of course 6 each of 2SA1312 and 2SC3324 per channel, and not 5.
Sorry for that,
Patrick
xen-audio.com
Old 15th December 2017, 09:23 PM   #89
A couple of question about the power supply...
I finished my PSU setup (see attachments) with schottky diodes in a dual bridge rectifier form followed by a 3300 uF Nichicon HW(M) 25 V capacitor per polarity and the Xen discrete regulator board. I have 2 x (25 VA / 2 x 15 V) toroidal trafos => one per channel feeding the PSUs. The question is: when not loading the PSUs I get +/- 14,99 V, but when I attach a load of 150 mA with 100 ohm resistors I get + 14,6 / 14,7 V and -14,9 / -14,8 V. Is this too much of a difference between pos./neg. if I consider a situation with no servo and CCS boards attached? How should I adjust the value of R1 to even out the voltages?
I’m preparing to build my test setup now with roughly matched devices but PSU setup will be the same for my final build with better matched BJTs.
File Type: jpg 8C87A876-4E09-4138-81A2-E09E3F6AFEC3.jpg (534.2 KB, 294 views)
File Type: jpg 6DEB68B7-D1A8-4C43-A3BD-FF3090C426E3.jpg (1.00 MB, 288 views)
Last edited by Morde; 15th December 2017 at 09:45 PM. Reason: Finally I got the attached pictures with iPad...
Old 15th December 2017, 10:12 PM   #90
The first thing I would check is whether the voltage drop at load comes from the regulators.
(They do have a small output impedance.)
It may well be that the drop comes from upstream, i.e. you do not have enough drop out voltage after the transformers.
You can easily test this with a regulated lab supply set at say +/-19V supplying the regulators directly.
In principle, if you do not use servo and also not CCS, then you will see the difference between rail voltages almost 1:1 at the output.
This you can trim out by adjusting the values of R9 or R10.
You can easily see their effect by changing their values in the Spice files.
Patrick
xen-audio.com
The Pioneer Super Linear CircuitHide this!Advertise here!
Sony Super Legato Linear latala Solid State 12 23rd January 2015 04:56 PM
AES E-Library: Super Linear Circuit by Ozawa, Okio; Ishikawa, Kikuo aparatusonitus Solid State 16 17th January 2012 09:49 AM
Linear PSU circuit gabanyayaya Power Supplies 7 21st July 2011 12:00 PM
Phase Linear 200 Circuit mrfeedback Solid State 4 5th December 2004 09:48 AM
