Headphone Systems Everything to do with Headphones
Lehmann headphone amp clone on aliexpress
Old 4th October 2017, 04:43 AM   #11
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yeah, 250ohm would suit 330uF (nearest standard value).
There are plenty of guys who hear differences between caps, I'm not one of them (yet). So I use a bog-standard electrolytic. Preferably not a low ESR one unless that's all you have as lower ESR normally means higher leakage.
You can size your cap according to the lowest impedance 'phones you're going to use. The only downside is a bigger (longer) switch-on 'thump' with the higher-Z kinds. This can be minimized though by fitting resistors (say 1k ohm) across your jack outputs to provide the ability to charge the cap with nothing plugged in. Then only plug in your cans a few seconds after powering up.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 4th October 2017, 09:10 AM   #12
ApolloZhang is offline ApolloZhang  Europe
Their Beyerdynamik A-1 copy is quite good, comparing to its price. (200 bucks or so)
Old 4th October 2017, 04:20 PM   #13
ammel68 is offline ammel68  United States
Banned
Originally Posted by Aatto View Post
i like that !
i found this for JLH :
NEW JLH HOOD1969 Class A Headphone amplifier PCB
what do you think ?
any suggestions on ebay/aliexpress ?
As I stated above, IMO the JLH smokes the Lehmann clones for SQ.
You can "roll" all the dual op-amps you want, but it still won't match the JLH's SQ.
DC offset is a big problem with the JLH and varies wildly depending on the temperature of the output devices.
Better AC couple that one for sure as abraxalito suggests.
Old 5th October 2017, 03:08 AM   #14
Aatto is offline Aatto  United States
Aatto's Avatar
will do the coupling thanks for the input
Old 5th October 2017, 03:12 AM   #15
Aatto's Avatar
yeah i did gave that one a try while back,i was happy with it till i tried this one :
GZLOZONE Lehmann HV-4 Headphone Amplifier Kit
I already bought this one a few weeks back :
GZLOZONE HV-5-TB Headphone amplifier PCB
i wanted to give this one a try since i had good experience with GZLOZONE before and since it's hybrid. there's no info on the board, lol, took a risk
JLH is next on the list
Old 5th October 2017, 04:30 AM   #16
Banned
Hmm...I've never seen that board before. Looks to be quite complex and uses a lot of components.
I have to agree that you took a BIG chance on that one, especially since I don't see a schematic for it.
Best of luck assembling it & working all the bugs out...LOL.
Old 5th October 2017, 11:11 PM   #17
Aatto's Avatar
i m very pleased with how it turned out tho, as for this board yeah, i m hoping for the best ( and not preparing for the worst ! ) lol, i ll let you know how it turned out, i ll probably receive it in a week or so.
pic from finished GZLOZONE Lehmann HV-4 amp :
Old 10th October 2017, 04:55 PM   #18
Gopher is offline Gopher  United Kingdom
I believe Sennheiser chose the Lehmann BCL amp to power their HD800 headphones at the launch. You might think they know a thing or two about headphones and amps, so surely the BCL can't be that bad??
Like most kit they can be tweaked to some extent for better sound, primarily the power supply.
Old 11th October 2017, 02:39 AM   #19
abraxalito's Avatar
Curious - why would Sennheiser 'know a thing or two' about amps? I used to work for a fairly well-known speaker manufacturer, we didn't know too much about amps. The choice of amps for demos was more often than not made based on commercial considerations, not SQ ones.
Old 11th October 2017, 09:44 PM   #20
Aatto's Avatar
it does not mean if they manufacture speakers/headphones they know everything about the amps or the other way around, if you are a painter it does not mean you know how paint was made or how to make it ! but as a experienced painter you know what paint to choose.
Lehmann has a good reputation and i m sure guys at Sennheiser tried different amps before they choose one , or it's like a contract or something.
Lehmann headphone amp clone on aliexpressHide this!Advertise here!
I need headphone amp. Lehmann? thyristor44 Headphone Systems 21 5th May 2017 06:03 AM
100Hz Hum in Lehmann Linear clone PsychoM Headphone Systems 33 24th April 2017 08:35 AM
[Headamp] upgrading a Lehmann BCL clone Cidious Headphone Systems 381 13th March 2017 08:40 AM
adding headphone jack to dynaco pas 3 clone rwshocker Tubes / Valves 1 27th December 2010 09:19 PM
lehmann headphone amplifier clone parhelia Headphone Systems 0 7th January 2010 01:00 PM
