Headphone Systems Everything to do with Headphones
Please technically explain this audible mod
Old 28th June 2017, 01:13 PM   #11
HotIce is offline HotIce  United States
That schematic has neither global feedback, nor a DC servo, and it can have some gain, so, without input decoupling capacitors, any DC component in input will be amplified (if the 680 Ohm resistor is wired, up to ~8 times) and set to the headphones.
I personally do not believe that any decent capacitor (that schematic, as component choice, reveals someone who has thought about quality - assuming parts are OEM and not clones) when made work within its limits (and especially in the input, with low/to-zero DC component across it), is going to affect sound quality.
This is a good read, in case you have no already:
Capacitor Characteristics
And this:
Blog - How Much Distortion Can We Hear With Music? | Axiom Audio
Old 28th June 2017, 04:37 PM   #12
DF96 is offline DF96  England
It may reveal someone who believes that 'quality' is found in particular component brands. It may reveal someone who believes that such brands are more important than getting the circuit right. Or maybe it just reveals what he assumes about the knowledge of his customers and reviewers. Sending DC to headphones is unlikely to improve the sound.
Old 29th June 2017, 12:54 AM   #13
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
https://www.lehmannaudio.com/headpho...me/linear.html
That's a lot of super glowing reviews for what appears to be simply an opamp with a BC550/560 and BD139/140 output stage?
Where is the innovation in this?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 29th June 2017, 01:32 AM   #14
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by elmura View Post
The purpose of the mod, as with any I do, is to attempt to improve the sound quality. This amp has great tonality but was missing clarity - a bit veiled.
As the schematic is a Lehmann (as xrk is pointing out) its very close indeed to one I had a play with a while back, wrote it up on my blog - http://www.diyaudio.com/forums/blogs...phone-amp.html
The TL,DR version is the poor dynamics turned out to be a function of the opamp's loading, poor OPS PSRR and also poor grounding. No changes to caps in the signal path were needed for satisfying sound.
So, armed with this measurement and the following schematic of a replica, do you still think my mod has caused a problem?
To get a handle on the noise currents flowing in your grounds, the layout is orders of magnitude more useful than the schematic.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th July 2017, 05:24 AM   #15
elmura is offline elmura  Australia
Sorry for the long delay to provide feedback. A computer failure, and 3 weeks illness to blame.
Based on comments & some analysis, I rerouted the 4 signal wires carefully; desoldered the original wires from the board (previously I only desoldered them from the RCA sockets); and desoldered the pre out wires in case of interference from torroidal transformer or external noise.
Glad to report that bass is juicy again, and soundstage has improved. But I'm still finding depth of stage not as great.
So my question is: do you think that the designers choice of joining the signal grounds together at the end of the board (closest to the RCAs) was causing more crosstalk, and thus deepening the stage?
I recall that prior to the mod, the stage was deeper, but the sound was more distant, less clear, less present.
Sent from my LG-D855 using Tapatalk
Old 13th July 2017, 06:09 AM   #16
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Ye basic noninverting op amp plus open loop diamond buffer affair.
C103,C104 are completely optional. C101,C102 are for safety's sake but if you know the input has no DC offset you can short them out it won't affect the electrical performance of the circuit.
Looking at the rest of the circuit though, I'd have to say that those capacitors are the least of the problems. Ugh. Even the position of the caps is wrong, they should be in series with R13,14 with a 47k resistor added in parallel with C105,106. As it stands the output DC offset will vary with the position of the volume control... a problem they try to alleviate by making R13,14 so large, which adds to the circuit noise. The op amp input impedances are not balanced properly either at DC or audio bandwidth.
Dual op amp - yuck. Dual op amp powered off RC filtered rails - double yuck.
And that diamond buffer. R26,27 and R30,31 are added to goose the output bias current, but they kill the PSRR of the buffer. Also 1.5k for R25,28,29,32 would be better off replaced with current sources for lower distortion, or at the very least increased.
RJM Audio website|blog
Old 13th July 2017, 11:24 AM   #17
mfratus is offline mfratus  United States
I would put those caps back in, and remove C105 and C106 or reduce their values to maybe 47pF. They shunt highs to ground at the input of the op amp. C103 and C104 are "sweetening" caps, attempting to pass more extreme highs. I would reduce R19 and R20 to 10 Ohms to firm up the supply. Yes, you could be getting DC from your source, and you could be getting extreme lows that are interfering with what you can actually hear.
Old 13th July 2017, 01:16 PM   #18
I just measured DC at source and output of the amp:
DAC: <0.2mV each channel
Amp: 13mV and 9mV
Also, as I have selected unity gain on the switches, volume on the pot is typically 12:00 to Max pending music source. So, what would the effect of removing R13/14 and reducing C105/106 values?
For reference, I've attached a pic of the internals with the current mod. The grey wires are the desoldered Pre Outs. The 4 wires are source and are positioned adjacent to the original PCB traces & soldered direct to the Pot
Old 13th July 2017, 01:29 PM   #19
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Without global NFB, the thermal inaccuracies or runaway of the output stage is uncompensated, and very risky for the earphones live.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th July 2017, 02:20 PM   #20
The Low Pass filter formed by the R13 & C103 (10K and 100pF) is significant. You can calculate the frequency. R13 is there probably to minimize the change as the pot is moved through its range.
The input circuit does leave much to be desired. The chip datasheet says, "To maintain low distortion, match unbalanced source impedance with the appropriate values in the feedback network as shown in Figure 28." Other's comments were right, using a variable resistor in the input leads to more distortion.
Instead of just removing stuff (it was in there for some reason) I would tweak the values. This is design work.
Please technically explain this audible modHide this!Advertise here!
Technically Accurate Speakers: Suggestions? Philosophil Multi-Way 57 26th April 2016 12:34 PM
Best pa subwoofer. (Technically) H Burch PA Systems 42 10th October 2013 12:03 PM
One for the technically minded... norman093 PA Systems 14 17th May 2012 05:04 AM
Not DIY Audio ...technically anyway, but..... quasi The Lounge 1 7th July 2007 10:54 PM
What is 'audible'? steve Everything Else 3 13th September 2004 10:56 PM
