Headphone Systems Everything to do with Headphones
"Estudiante" Hybrid (7370 + MOSFET)
Old 17th October 2017, 11:30 AM   #21
twocents is offline twocents  South Africa
twocents's Avatar
Originally Posted by xrk971 View Post
It's that opaque ampule shape in the middle. Two Raytheon compact tubes. Probably used on 1960's jet fighters.
Interesting - never seen it before. I thought they were some boutique or Russian caps.
Originally Posted by JPS64 View Post
Listening not bad with high impedance headphones (HD600, DT880 600R), lets say more bass as Wayne´s HPA supplied with +/-18VDC?!
This is what I am interested in. I don't really need another headamp but would like to try this one sometime in future. I'm just drawn to simple schematics/designs that work/sound good - and this one seems to fit that bill.
Old 17th October 2017, 02:29 PM   #22
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It is very simple and you can simplify further by replacing the active LM317HV CCS (which technically adds an opamp with 20 transistors to the circuit) with a simple 5w 220R wire-wound. There is possibility of quadrupling the output power (passively) by replacing the resistor CCS with a properly sized inductor. A large many tens of mH low DCR one (a big spool of magnet wire works) or an air gapped steel core one for compactness. The reactive nature of the inductor amplifies the amount of voltage swing for more power.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 10th November 2017, 10:28 PM   #23
00940 is online now 00940  Belgium
00940's Avatar
I just had a look at the amp in the op. With 20v at 130ma heaters, you could use them as load for the mosfets... That's what was done in the famous Melos sha1. It works surprisingly well.
All that is excessive is insignificant. Talleyrand
Old 11th November 2017, 12:39 AM   #24
Sodacose is offline Sodacose  United States
Sodacose's Avatar
The 7370 draws 260mA at 20V with the two heaters in series. You could ground the CT and give both halves of the heater 20V. I thought about trying this (just like Millet does it with the SSMH, too) but I was also keen on trying to direct couple the stages and was worried about how consistent the heaters would be. If I build another one of these, I'll probably give this a shot (maybe cap coupled). Could be a little more compact by eliminating heatsinks.
The 417A is a 20V 100mA heater and I thought about using two halves in parallel the same way, but the plate curves didn't look like it would like the low B+ (even in parallel).
WTF Amps || /r/diytubes/
Old 11th November 2017, 11:45 AM   #25
Got Foam?
xrk971's Avatar
You would still need sinks on main MOSFETs. Would not the variying pulsing current in the heaters, in this way perhaps drive some unwanted feedback? I guess one could put such big caps to filter it and make it very steady though.
Old 11th November 2017, 12:12 PM   #26
Sodacose's Avatar
Yes, eliminating some of the heatsinks is what I should have written. Still needed for the mosfets.
As far as feedback, only trying it would give one a good idea. Heaters on indirectly heated tubes are frequently run AC silently but in some cases you can get some of the mains frequency in the output. Whether that is the heater/cathode interaction or just wiring best practice is another question.
In this hypothetical case, we would have an inverted signal at the cathode, so nfb. Not necessarily a deal killer even if there is some small effect.
Old 17th November 2017, 10:37 AM   #27
JPS64 is offline JPS64  Germany
Here, after successful test, 1AD4/IRF510 Headphone Amplifier.
I will order a batch of 5.
JP
Old 17th November 2017, 04:17 PM   #28
Got Foam?
xrk971's Avatar
Nice work JP. What DC-DC step up are you using? Note that you need to use the LM317HV for the CCS of the SE Class A output stage. I tried regular LM317 and it did not work. Very finished design.
Old 17th November 2017, 04:30 PM   #29
Sodacose's Avatar
I bet with the 24V supply it will be ok.
I think the issue with the Estudiante and 'regular LM317 was at start up. The gate would see the full supply voltage because the tube heaters had not warmed up. This was essentially dumping all 48V across the CCS and the supply was probably cycling at the same time because of the heater current draw. I've seen builds work without the 'HV' but it probably comes down to the supply used.
I updated all of my docs to specify LM317HV. It was listed in places (that's the part I built my own with because I had them) but I didn't reinforce the importance.
At any rate, JP's project (awesome job, by the way) shouldn't have the same issue with the regular LM317. I'm interested to see the rest.
You know you could easily make it portable with just a couple of standard 12V car batteries in series
Old 22nd November 2017, 05:46 AM   #30
Got Foam?
xrk971's Avatar
Or a big fat 10,000mAhr 3.7v LiPo pack and a small $5 DC-DC step up board.
"Estudiante" Hybrid (7370 + MOSFET)Hide this!Advertise here!
lGl-2, continuing "hybrid madness" - no GNFB class A vzaichenko Solid State 225 18th February 2015 05:22 AM
"Hybrid A-1000" - Very Old MOSFET amp duane2012 Solid State 3 10th September 2012 05:59 PM
A "Vintage" Integrated Amp Inspired Hybrid regal Headphone Systems 1 29th December 2011 07:12 PM
Jfet/opamp "hybrid" phono stage 00940 Analogue Source 8 11th March 2011 06:29 PM
Hybrid amp Aloia GY-50 "a step beyond of" Stee Solid State 12 27th January 2011 07:19 AM
