Death Of Zen Headphone Amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 21st January 2017, 03:28 AM   #1
Default Death Of Zen Headphone Amplifier
Progress Of my diy Death Of Zen Headphone Amplifier (Server yes thats a raspberry pi)
The Most recent of my youtube videos:
https://www.youtube.com/watch?v=QP2boI2eDIg
Old 21st January 2017, 04:18 AM   #2
My first idea starting this Project was just to have a super clean Class A amplifier. This project for me has morphed into a small project to a huge one. It has came from normal headphone amp to a flagship amplifier.
I have added on (because i though it would be a cool) a Raspberry Pi hence the server part of my project. At this current moment the server side is not complete and is in the works. I plan on using Volumio 2 as my primary software. I also plan on making videos of all my progress. Please Join me in the completion of this awesome project. My YouTube channel is called iybtech. I plan on making more videos with all my projects in the future.
Old 21st January 2017, 04:59 AM   #3
Old 21st January 2017, 12:18 PM   #4
The DOZ amp that i built is designed by Rod Elliot (Death of Zen Class-A - Use it as a headphone amplifier)
Supply Voltage 20V
Suggested Quiescent Current 200 mA
Maximum power See Table 1
Output Noise (unweighted, 1k ohm source) <1 mV
Distortion @ 1kHz, 4V RMS at output < 0.4%
Output Impedance 120 ohms
Frequency Response (-0.5dB @ 100 mW) <20Hz to >50kHz
I happen to be running the amp at 36v with a Quiescent Current of 330ma. I will be lowering the Quiescent Current down closer to 200ma sooner than later.
I had it higher for stress and heat distribution testing. Another slight change from the original design is the omittance of the 120ohm feed resistor.
If anyone has good Instructions I would like to test it on a oscilloscope? I don't know where to start for basic tests but i have the equipment available.
Old 21st January 2017, 03:17 PM   #5
e_fortier's Avatar
Nice project.
Can I ask you where you bought your case ?
Thanks,
Eric
Old 22nd January 2017, 02:16 AM   #6
I Bought it in Okinawa at a nice place called Okinawa denshi's. It cost 5000 yen which is about 50 dollars.
Old 20th February 2017, 05:03 PM   #7
Below is video about the server section of my project and it simple configuration.
https://www.youtube.com/watch?v=jziPhAEy1vs
Death Of Zen Headphone Amplifer/ Music Server iybtech Headphone Systems 2 23rd November 2016 09:21 AM
Death of Zen 15 watt Power Amplifier shaan Solid State 180 22nd September 2015 06:12 PM
Zen headphone amplifier lacking in bass hansel Headphone Systems 13 2nd April 2006 08:18 AM
I have maked a Zen Headphone Amplifier Kit digi01 Headphone Systems 14 10th March 2003 02:12 AM
Copyright 1999-2017 diyAudio
