Headphone Systems Everything to do with Headphones
MOSFET Source Follower Headamp
Old 26th December 2016, 07:08 AM   #21
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by AKSA View Post
No, X, it will not change the gain at all.....
Really interested in the results. I have a feeling it will improve the resolution, not that it needs it! Making something wonderful spooky supernatural, huh?
Hugh
OMG, it really worked well Supernatural spooky good is how I would describe it now. I changed the input caps to a Panasonic 560nF 100v MKT's (maybe has something to do with it as well?).
Thank you for that tip!!! I did not think it could get that much better but wow.
And the gain stayed the same. I switched the 1M SMT to a 220k.
Very very detailed or high rez as they say, or as the people in the music biz say, "It's dope!"
Extreme resolution but not harsh or artificial - just really really amazing. I think overall SQ in the whole range improved as mids sound even more lush and bass sounds even deeper. All subjective of course so don't flame me. It's just what my ears are telling me.
I did listen to two tracks immediately before and after the mod so that my memory has something to go by and I am not just being enthusiastically spouting placebo hyperbole.
Old 26th December 2016, 07:43 AM   #22
AKSA is offline AKSA  Australia
Hmmm, I gotta build me one 'o these critters......
Thanks X. Chrissy pressie?
Ciao,
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 26th December 2016, 07:50 AM   #23
Got Foam?
xrk971's Avatar
Ciao,
Hugh
You really should. Are you talking about the preamp or the whole system?
The whole system is really not that much more. In the signal path are 7 FETs and two JFETs acting as bias setting CCS, so technically 9 actives. But there is hardly anything complicated about it and perhaps that is why it sounds so good - following the NP approach of simplicity in circuitry helps SQ.
I am so jazzed about this I want to box it immediately so I can take it with me.
I am listening to stuff from my XMOS U8 DAC at 176kbit so that the detail can indeed come out.
Blue Rondo a la Turk, Take Five, Impressions of Toledo, Keith Don't Go, and a bunch of deep bass House dance mixes. All fantastic.
What does
Chrissy pressie
mean? Xmas present?
Old 26th December 2016, 08:36 AM   #24
X,
The CFH7 is an outstanding amp, but I have seen this before in the original Japanese and generally avoid symmetrical circuits. This is just my preference; I like single ended circuits, like your jfet HPA.
Accordingly, I would like the build the preamp for a headphone, though I have been examining the jfet circuit with HPA applications and it's range is very limited. I built one three years back using bipolar/mosfet CFP supplied from a smps at 48V and the sound was astonishingly good. I suspect your version is superior, so a build is on the cards......
The harmonic profile at 1Vp into a 280R headphone (I have a Beyerdynamic DT880 too) is typically H2 -55dB, H3 -79dB and H5 -86dB. This is very like the profile out of a plate loaded triode, and for the same reason because the topology is plate loaded directly connected to cathode follower. The transfer function of a tube, power 1.5, is quite similar to a jfet, power 2, so their distortions are similar. The great advantage of jfets is their quiet behaviour, low voltage and the lack of a filament! This is as close you get to a tube circuit without bottles, and I believe the
resolution is superior.
I have been simulating the source load for the second jfet. If you replace the bottom jfet and replace with 680R you lose nothing and you reduce the parts count. Most of the output voltage is driven from the first, voltage stage, so changing the bottom CCS with a resistor has no effect on the range. Whether it affects the SQ would be moot; I suspect not. It would increase the output current from 9mA to 12.5mA, giving a dissipation of 119mW using 18V supply (to be just within the 20V max on the datasheet).
At -6dB output (1.42Vpp into 280R) H2/H5 is -52dB/-85dB, close to a triode circuit, but not much more than 4Vpp output before the negative trough starts to badly distort.
This is a classic triode circuit, converted to jfet, with bad measurement figures, low dynamic range and limited drive but with celestial Sound Quality - harps on heaven stuff. It is proof positive that many of the variables we audiophiles use to assess quality are completely off the mark. There is clearly a lot of psychoacoustic stuff we do not measure.
Hugh
www.aksaonline.com
Old 26th December 2016, 09:01 AM   #25
Got Foam?
xrk971's Avatar
Hugh,
Are you talking about dropping the bottom BF862 on the preamp or the bottom LU1014D on the power amp stage to reduce parts count without affecting SQ? When you it has low dynamic range is that theoreamp stage or the power amp stage? The poweramp stage is running about 400mA bias righ now. I don't feel it has limited dynamic range on my DT880's.
The power amp is based on this circuit, with J511 replaced by J310 and 470R in CCS mode and the 8.2Z replaced by 6.8Z and red LED, and IRFP240's for the 2SK1529 MOSFETs.
Old 26th December 2016, 09:23 AM   #26
Sorry, X, I'm talking only of the BF862..... the dynamic range (that is the max Vpp output) of the BF862 is about 4.5Vpp output.
However, your LU1014D circuit is interesting too.... question: do you need a 100R stopper on the two bases, because in my experience highish stoppers damage the music badly. What sort of beta do you have on these devices, I understand the beta is LOW on these. I have always been confused about WHY they are used in audio, their low beta, high base and speed issues make them suitable for power traction work, don't they? And they are EXPENSIVE.
Chrissie Pressie is Xmas present, as you guessed......
Hugh
www.aksaonline.com
Old 26th December 2016, 01:11 PM   #27
Got Foam?
xrk971's Avatar
The LU1014D is kind of unique in that it is a power JFET capable of huge currents. It's not expensive. Matched pairs for $6 I think. Unmatched for about $1.50 ea. I think they sound quite nice. I don't know why 100R used on gates other than to suppress potential instability. Maybe can be bypassed - can try easily. Do you expect SQ to improve as well?
http://www.amplimos.it/images/LU1014D.pdf
If you like the BF862 as a power amp - I did that too. Four pairs in parallel in SE mode. More here:
http://www.diyaudio.com/forums/headp...hout-heat.html
Predicted FFT as built:
Sounds quite nice but can't match the dynamics of the title HA.
Old 26th December 2016, 01:18 PM   #28
didiet78 is offline didiet78  Indonesia
Lu1014 have triode curve
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 26th December 2016, 02:41 PM   #29
EUVL is offline EUVL  Europe
Hugh,
May I clarify for you of the origin of these circuits posted here.
The LU1014 Follower being posted here and elsewhere originated from me in 2007.
MOSFET follower headphone amplifier
It has long been superceeded by later versions.
http://www.diyaudio.com/forums/headp...amplifier.html
You can find detailed published information of those circuits in the original threads.
The SRPP + White Follower was originally from easphyx
http://www.diyaudio.com/forums/solid...amplifier.html
The BF862 version was posted by me at the same thread, for the sake of exchange of circuit ideas.
http://www.diyaudio.com/forums/solid...ml#post4895179
I did not, and shall not build because I don't build amps with decoupling caps.
Patrick
xen-audio.com
Old 26th December 2016, 05:24 PM   #30
Got Foam?
xrk971's Avatar
Originally Posted by EUVL View Post
Hugh,
Patrick
Don't worry EUVL - I credited you with all this in the first post of this thread if you had bothered to read. You wanted me off your threads and said you wanted nothing to do with my builds because heaven forbid, I don't match my JFETs. So now I am here in a different thread. Why follow me then?
MOSFET Source Follower HeadampHide this!Advertise here!
Mosfet source follower regulated supply kacernator Solid State 10 26th January 2018 06:10 AM
step up transformer on mosfet source follower ? AudioGeek Solid State 0 8th February 2016 02:57 PM
Mosfet source follower output impedence pds8788 Solid State 9 5th April 2014 05:50 PM
mosfet source follower output stage. Printer2 Tubes / Valves 21 18th January 2013 04:43 AM
load on source follower choke or mosfet? AudioGeek Solid State 57 2nd September 2004 02:42 AM
