BF862 based SE Class A Headamp without the HEAT - Page 42 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th April 2017, 12:37 PM   #411
http://cds.linear.com/docs/en/datasheet/3042fa.pdf According to Figures G43/G50 PSRR and noise are getting better with lower current (down to 1 mA).
p.s.: For maximum performance - stability and low noise - you should be careful with C_set both low ESR and low ESL is required.
edit: the "cover" graph TA01b of the datasheet is a bit missleading saying that psrr up to 120db can be achieved with 200mA (G43 vs TA01b Cset 0,47uF vs 4,7uF other parameters are the same).
Old 29th April 2017, 04:48 AM   #412
A few posts back I joked about being goofy and stacking SMT caps on top of each other, and soldering on leads. Turns out this is a real thing...recommended by Murata, in fact! They say you can stack up to five of them. This opens up some options...It'd be possible to create a 5x1uF C0G cap to fit in the narrow space for C1 on the PCA. Or even better, a 2x1uF PPS.
A high capacitance monolithic ceramic capacitor | Leaded Products | Murata Manufacturing Co., Ltd.
File Type: png Screen shot 2017-04-29 at 12.23.03 AM.png (136.9 KB, 843 views)
Old 29th April 2017, 05:08 AM   #413
xrk971 is offline xrk971  United States
xrk971's Avatar
I have these tiny 10uF 50v MLCC caps with leads. I used to use them for input coupling and would bypass with a 1uF film. But now I worry that they may have high distortion since not C0G. Probably X7R so I use them for power filtering only. They look like stacked SMTs. Tiny little packages dipped in epoxy.
Old 4th June 2017, 11:59 PM   #414
xrk971's Avatar
I tried an amp with 10uF Silmic on input with 1uF MKS Wima film as a bypass. On output using 1000uF oscon with 100uF Silmic as the bypass. Observing the 10% rule of thumb. I don't know. Sound a great though.
Old 5th June 2017, 09:42 AM   #415
kees52 is offline kees52  Netherlands
With capacitive outputs I did always use 1 nF 100 nF over the real big electrolite output cap, however for input the same, the hybrid of mine has 1 nF and 100pF parallel over 470 nF input cap. better audio pass through, or maybe a hoax, but I did hear the difference, tighter and faster,
Old 17th June 2017, 08:12 PM   #416
JPS64 is offline JPS64  Germany
PCB ordered: 10F ELNA SILMIC SMD on input; 4x 220F OSCON + 022/MKP2 + tbd FKP2 on output; TKD potentiometer; NiMH/NiCd charging electronic.
Preparing 3D Printing datas for enclosure online ordering...
JP
Old 17th June 2017, 09:12 PM   #417
xrk971's Avatar
JPS64. That amp looks very nice. Is that a stack of PCB with bias used as a heatsink extended "fin"?
Check out the Silicon Harmony (6w into 8ohm single ended):
Click the image to open in full size.Click the image to open in full size.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th June 2017, 10:48 AM   #418
diyRookie's Avatar
Well done X! What a beautiful beast. I can only dream of building something like this one day.
Looking forward to reading all the reviews, and I hope the orders start streaming in.
Old 19th June 2017, 04:49 PM   #419
xrk971's Avatar
Thanks DIYRookie. It is indeed a beast: hot and heavy to hold when fully warmed up.
But the sound is glorious.
Slight correction. Measuremts show max power is 5w into 8ohms before clipping.
Old 22nd June 2017, 03:20 PM   #420
xrk971's Avatar
Tidy wiring with SMPS moved inside.
Universal buffer/headamp based on OPA1622 OlegSh Headphone Systems 237 Yesterday 11:45 AM
LME498xx Based Headamp panson_hk Chip Amps 20 9th April 2013 10:20 PM
GB: BF862 Based Preamp npapp Group Buys 68 3rd February 2013 10:39 AM
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 07:08 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
Copyright 1999-2017 diyAudio
