Headphone Systems Everything to do with Headphones
BF862 based SE Class A Headamp without the HEAT
Old 17th November 2017, 06:44 PM   #501
Mayday is offline Mayday  Sweden
Mayday's Avatar
Originally Posted by xrk971 View Post
The top is at 19v but their source is at 10v (as can be seen as input to drain of bottom FETs), so net result is only about 9v Vds on top FETs.
So do you have first sound yet?
I see what you mean. You are of course correct.
No, no sound yet as I don't like the high DC-offset with the volume all the way down.
I'm trying a different things to see if I can remedy that.
Is this something you have come across?
I may have brainf@rted, with a capacitor on the output, it needs a load...right?
The more you learn, the more you realize how little you know...
Revived my blogg
Old 18th November 2017, 01:41 PM   #502
Mayday's Avatar
I put the oscilloscope, well the closest thing to it I have atm, a DSO138 on the DAC output and Edcor secondaries.
I got nothing but jibberish. I sent 1Khz sine & square wave via audacity.
Conclusion, the error I made that caused the PS to not reach full voltage killed the CS4397 IC. I've got a new one on the way.
While having the thing apart, I desoldered the 470uF/25V ROA Cerafine output caps and the Silmic II 100uF/25V PS cap. I soldered the Cerafine back in but as PS cap.
I'll put a 1000uF/10V Cerafine as output cap and bypass it with a nice 1uF MKP.
I also ordered some more of the 33R Takman 0.25W metal film resistors to put in parallel with the ones already on the headamp boards. That would put bias from about 8mA to around 10mA per jfet. That, and the bigger output cap with bypass cap should be an improvement with regards to SQ.
I really need at least a Hantek DSO5072P or similar, hard to justify the expense with the missus though as "I have too much crap as it is " lol.
Revived my blogg
Old 22nd November 2017, 06:39 AM   #503
xrk971 is offline xrk971  United States
xrk971's Avatar
Yes, something like 270ohms to 470ohms should work to bleed off the cap due to initial turn-on. Otherwise your cans will go thump when you plug them in.
Nice thing with cap coupling is it is inherently safe for your cans.
I got an Owon SSO8192V 100Mhz 1G/s 8" LCD Display 1M Depth Memory VGA Port Oscilloscope for about $270. Works great - 1M depth is very nice and huge screen compared to Hantek.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 27th November 2017, 01:59 PM   #504
Mayday's Avatar
I got the Cerafine 1000uF/10V caps and the additional 33R Takman resistors today.
Haven't really had much time for diy the last couple of days, but I hope to get the headamp fully populated again in the next few days.
Revived my blogg
Old 27th November 2017, 04:49 PM   #505
Mayday's Avatar
Well I got a little more done today
I populated the output capacitors and the extra 33R Takman resistors(on one of the boards as I wanted to test bias in both setups).
I used a 9V battery as power supply.
33R in parallel for 16.5R gave 6.97mA, 33R as is gave 5.30mA.
I did put a Wima MKS2 4u7 across each output capacitor.
I got a 0.001mA difference between all output pairs. I'm ok with that result.
The pics show only one, the first, resistor I put in parallel with the ones already on board.
Revived my blogg
Old 15th December 2017, 01:56 PM   #506
xrk971's Avatar
Mayday,
Are you playing music yet?
Old 15th December 2017, 03:48 PM   #507
Mayday's Avatar
Nope, unfortunately not.
Got the 22Vdc supply the other day, it rattled and measured at 0Vdc...
My painlevels hasn't really allowed much diy lately either.
Revived my blogg
BF862 based SE Class A Headamp without the HEATHide this!Advertise here!
Universal buffer/headamp based on OPA1622 OlegSh Headphone Systems 299 3rd December 2017 05:16 PM
LME498xx Based Headamp panson_hk Chip Amps 20 9th April 2013 11:20 PM
GB: BF862 Based Preamp npapp Group Buys 68 3rd February 2013 11:39 AM
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 08:08 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 09:08 AM
