Headphone Systems Everything to do with Headphones
BF862 based SE Class A Headamp without the HEAT
Old 6th November 2017, 01:47 PM   #471
Mayday is offline Mayday  Sweden
Project Horder & Blogger
Mayday's Avatar
They are 13.4 to 13.8mA IIRC.
The more you learn, the more you realize how little you know...
My blog, go have a look
Old 8th November 2017, 07:24 AM   #472
Mayday's Avatar
I went over the boards with the DMM, with PS wires connected as in the attached pics, I got about 22R between VCC and GND. Is that correct?
I had to use 10000uF/25V Dubilier (x2) and 1000uF/35V Panasonic FC as there's no way to fit two of the 22000uF caps on the board.
Edit: resistors on GND side are not yet populated.
Old 8th November 2017, 02:17 PM   #473
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Looking good Mayday!
BF862's are N-junction depletion-mode FETs, which are normally conducting (self-biasing capable) when no voltage is applied to the gate. 22R is probably result of natural conduction in the nominal no-voltage applied state. With a 20v rail that would be nearly an amp, nut max is limited by Idss of BF862 (around 10 to 25mA). I think nominal operating bias current is about 50mA to 60mA if I recall, so should go down once powered up.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 8th November 2017, 02:38 PM   #474
Mayday's Avatar
With the boards not connected via PS wiring I got 42R.
The devices are 13.4 to 13.8mA Idss.
I got the resistor needed to complete the headamp today. 715R as I didn't find 710R, does that matter?
Old 8th November 2017, 07:59 PM   #475
Got Foam?
xrk971's Avatar
Sorry you were waiting on that. Not critical at all, anything from 220R to 2k would have worked
Old 8th November 2017, 08:11 PM   #476
Mayday's Avatar
Well, no worries as I still need to get two more 5W resistors for the CRCRC filter.
Gives me the chance to work on the enclosure for the DAC/headamp combo.
Today I sanded and put the first layer of varnish on the wooden side panels.
Edit: I have two of the same enclosures, that's why there's 4 side panels.
Old 8th November 2017, 08:52 PM   #477
Got Foam?
xrk971's Avatar
1W or even 500mW resistors can work for your CRC. We are taking flow of maybe 120mA here Class A so steady.
Old 9th November 2017, 03:38 PM   #478
Mayday's Avatar
Put a second layer of varnish on the wooden sides.
I also started drilling holes in the alu-enclosure.
Also attached a picture of the DAC board and the XMOS board that will feed the headamp via edcor WSM transformers (600:2K4).
Old 9th November 2017, 04:06 PM   #479
Got Foam?
xrk971's Avatar
Nice work. You did a DIY DAC? Very cool. I like xmos USB adapter too. I got this and it works quite well. Has BB PCM5102 DAC. Nowadays I mostly use the Focusrite 2i4 2nd gen as a DAC and that sounds very good too. Capable of high speed rates.
New version Assembled XMOS U8 + PCM5102 + TDA1308 USB Coaxial DAC Sound Card 32bit 384K headphone Output ,Free Shipping-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Old 9th November 2017, 04:18 PM   #480
Mayday's Avatar
I have several DIY DAC's in different stages of completion lol.
Dual pcm1794, 3pcs populated Red Baron boards, a WM8740 board, two XMOS boards (one is the later XU208 IC), 3pcs audio-widget USB to IS boards of which one is populated and flashed with firmware, a few WM8805 SPDIF to IS boards (had those made by a board house, the dual pcm1794 too as it's a 4 layer board), one 8x TDA1387 board nearly done, one ES9018K2M board, two or three ES9023 boards and one analog metric completed dac with passive I/V and tube output.
A home etched WM8804 SPDIF to IS board (most fine pitched board I've etched thus far).
I think I remembered them all lol
BF862 based SE Class A Headamp without the HEATHide this!Advertise here!
Universal buffer/headamp based on OPA1622 OlegSh Headphone Systems 299 3rd December 2017 04:16 PM
LME498xx Based Headamp panson_hk Chip Amps 20 9th April 2013 10:20 PM
GB: BF862 Based Preamp npapp Group Buys 68 3rd February 2013 10:39 AM
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 07:08 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
