Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Headphone Systems Everything to do with Headphones |
#161 | |||||
I understand the whole 24-hour/day thing. I can also empathize with getting excited and wanting to share "data" even though hard data doesn't yet exist. I do understand that some view the correlation between good measurements (plural) and good listening experience with skepticism. I disagree but respect their opinion. However, "designing" a circuit without even measuring the output power or even looking at the output waveform on an oscilloscope and then making claims about increased power (or other performance parameters) is basically the blind leading the blind through a minefield in the dark. It is certainly more risk than I'm willing to take on. You can have a circuit that sounds great but oscillates at 100 MHz (been there, done that). It may work fine with some headphones but fry others. If you're planning to offer your designs for sale, I strongly encourage you to measure the crap out of the circuit to make sure you never ever get that support call starting out with, "Um... Yeah.... Your amp fried my $5k headphones. Now what?" At least I don't ever want to end up in that position, which is one of the reasons I apply the same level of engineering and expertise to my Neurochrome designs as I used when working for National Semiconductor and TI when my circuits were mass-produced by the hundreds of thousands if not millions. If you intend to play in the DIY market, you'll also have some savvy DIYers out there who'll measure the crap out of your circuit to hone their measurement skills and perhaps keep the honest people honest. If you guess your "specs" based on "should" and "probably" you'll likely have some angry forum posts to deal with. This can kill your business before it even gets off the ground. Just saying... Quote:
The source follower is great at sourcing current. It won't sink more current than its quiescent current, though. Nothing wrong with that but it does impose a limit on the output current and will result in asymmetrical clipping behaviour. Quote:
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits. Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right |
#162 | |
Tom
#163 | |
The HP-1 can deliver 450 mW into 300 Ω. This is enough for 124 dB SPL, assuming the headphones don't disintegrate by then. That's enough for 104 dB SPL average assuming a 20 dB crest factor (10:1 amplitude ratio). 20 dB is applicable for good recordings of classical music. For average music 14 dB is commonly used and for heavily compressed music 6 dB is used. So you're looking at 110 and 118 dB SPL (average), respectively. That's LOUD! ~30 dB louder than the OSHA threshold for when hearing protection must be worn in the workplace, for example. The HP-1 runs on ±18 V rails. That's not to say that some won't desire more power. That seems like a pretty universal trait regardless of market segment. ![]() Tom
#164 |
Got Foam?
My battery powered SE Class A amp can't deliver the kind of power your Class AB chipamp can do that's for sure. But the balanced drive does work to almost double the output swing. In single-ended output I get about a 5.56v peak-peak output into a 270R load, whereas putting it into balanced drive mode I can get about 10v peak-peak. It's not quite 2x the voltage probably due to the limitations of this topology and the limited 55mA bias current. But it definitely boosts the output while keeping the amp working well within its lower distortion range. One thing to note, you need a battery powered o-scope in order to make the floating ground measurement in balanced drive mode. Here are some screenshots.
Single ended drive mode (5.56 Vpp): ![]() Balanced drive mode (10.0 Vpp): ![]() Edit: for the single ended mode, I used the built-in 270R load resistor that is always present on the PCB, and for the balanced mode I have an extra added 270R load externally in between the two outputs. Thus the load is lower impedance in the balanced drive mode and hence max output swing is less.
XRKaudio https://www.etsy.com/shop/XRKAudio Last edited by xrk971; 6th July 2017 at 09:57 AM. |
#165 |
Great! How about 32 Ω or 20 Ω?
Tom
#166 |
Got Foam?
My friend who loaned me the battery powered scope took it back today. My wall plug non-isolated scope doesn't work to measure floating signals. It shows clipping like artifacts. Nonetheless, the Pocket Amp was designed for portability and longer battery life in Class A so then bias was a modest 55mA - suitable for 250ohm and higher headphones. I am certain that clipping will occur at lower voltages than for the 270ohm/180ohm case. If I built some SE Class A headphone amps designed with higher bias for 50ohm headphones, I think it will be fine. Actually I guess I can try it out with my Silicon Harmony, which runs a 1100mA bias current and should handle even 8ohm headphones. I will only get one channel of balanced drive though.
XRKaudio https://www.etsy.com/shop/XRKAudio |
#167 | ||
![]() Quote:
Tom
#168 |
It's been a busy few days soldering. Two of these ship Monday morning.
Tom
#169 |
Congratulation orders is coming in and great picture there it looks 3x as good as post 120
#170 |
Thread | Thread Starter | Forum | Replies | Last Post |
Looking for a high-end DiY headphone SS amp | BucketInABucket | Solid State | 30 | 24th August 2015 06:38 PM |
HPA-2 Headphone Amp Kit (High quality & High-end components) | kawo | Group Buys | 20 | 17th February 2012 04:34 PM |
Ultra-High-Performance Headphone Amp TPA6120 as FrontEnd for Quad-303 Super-ß Triplet | tiefbassuebertr | Solid State | 3 | 24th April 2011 05:35 PM |
HLLY HIGH END DMK-IV DAC with Headphone AMP | hllyelec | Swap Meet | 4 | 18th November 2009 09:28 PM |
Ultra-high end DIY amp recommendations | mlihl | Solid State | 12 | 11th September 2004 08:05 PM |
New To Site? | Need Help? |
