Alternative to the lme49713 ?
So TI discontinued the soic version I've been using in a project as output buffer in a composite amp. I've quite a few pcb left I'd like to use but no lme49713 left.
Any idea on an alternative ? It must be:
- fast (it's inside the feedback loop of another opamp);
- a single opamp;
- in soic package;
- with decent output current (the lme was close to 100mA);
- ideally with higher than +/-5v rails.
jackinnj: thx, I might contact you :)
Sergey888 : oh, there's no fixation on cfa. My first choice for that amp was the lm6171 and I will probably go back to it. (see http://www.diyaudio.com/forums/headphone-systems/261952-opa2134-lm6172-composite-amp.html ). To be true, I had not realized that the lm6171 had twice the current output of the lm6172.
chris719: I've used the tpa in the past but it won't fit the existing board.
abraxalito: not a bad catch but the max +/-6V rails are a bit low. Thx for the suggestion though.
