Headphone Systems Everything to do with Headphones
E19 headphone amplifier board K2381 J407 MOSFET Yuanjing Audio
Old 7th September 2016, 01:48 AM   #21
keilau is offline keilau  United States
Originally Posted by HotIce View Post
Where did I say, or even imply, that my design are better than "the rest of you"?
You asked for a suggestion for an ebay kit, and I told you I am sorry, but I prefer not to buy ebay kits, and hence have no experience to suggest one.
There are countless schematics on this site, with people sometimes offering PCBs.
If not, you can have PCBs made for cheap (using the posted Gerber files), and head to Digikey or Mouser to pick the various components.
Clearly, it is going to be more expensive than an ebay kit.
But if you consider the probability of getting a lemon by buying ebay kits, and you include that into the cost, that "more expensive" might suddenly look not so expensive after all.
I started this thread for a specific Ebay kit, the E19 headphone amp. It is to share information on how well it works and how to make it better.
Layout of double sided PCB is beyond the skill of me, and most other forum members. It is not for everyone. The E19 is meant for a fun weekend project.
If this type of project is below your level, please, start your own thread.
Old 7th September 2016, 02:09 AM   #22
Originally Posted by ammel68 View Post
Several different amps have been mentioned here.
Is the E5 as good or better than the E19?
The E5 is a good board of known quality. The E19 is a reject which has design defect and needs Nattawa's fix to make it work. No comparison.
Is the more expensive "Reference HA5000 amp" suppose to be better than the E5 and E19?
The "Reference HA5000 amp" has more drive current capability on paper and may work better with low impedance phones. But the quality is unknown. If it works as advertised, it should be a more dynamic amp. Wish someone who had used the HA5000 clone will post.
Old 7th September 2016, 02:57 AM   #23
ammel68 is offline ammel68  United States
Banned
Let me rephrase my question since I wasn't clear.
I'm wondering if the E19's sound quality is better than the E5's and if the HA5000 clone's is better than both of the E models?
I understand that the E19's board is crap and the E5 works right out of the box.
Old 7th September 2016, 05:20 PM   #24
I will be very interested in the answer to your question too.
The E5 is best documented among the 3 by its creator, Weiliang, on this forum:
http://www.diyaudio.com/forums/headp...phone-amp.html
The E19 uses the same topology which may make it sound similar, but the devil is in the details. Nattawa built both and may have some insight.
The Audio Technica HA5000 is a $1200, very highend box. The clones may not follow it to the letters. You can find a discussion of the HA5000 at the RJM Blog on this forum. On paper, it is a better design than the E5/E19 using similar topology.
http://www.diyaudio.com/forums/blogs...48-ha5000.html
Old 13th September 2016, 04:45 AM   #25
Originally Posted by nattawa View Post
I hope you did not get the same E19 that I ordered at ebay. <snip>
I put a 470uF/25V cap and the hum does not go away. It is very low level, but very bothersome. I may have solder the cap in such a way that there is still a ground loop. Back to the drawing board.
Otherwise, the E19 amp sound very, very good.
Old 13th September 2016, 02:54 PM   #26
nattawa is offline nattawa  Canada
It probably matters where you solder the capacitor GND terminal. I soldered it right to the center pin of the AC input connector. If you have a smaller power rating transformer it may help, for its higher winding resistance helps reduce the peak charge current on the main caps. you could also insert a 1-ohm/1W resistor in each of the 12VAC inputs to help reduce the peak charge current.
If the above does not suffice, it may take cutting up the traces and cleaning up the way the rectifier-smoothing cap current loops to establish a quiet common "Ground" that the amplifiers reference to. The attached picture is the C-R-C filter I now have with my E19, it was hard wired, and solder joints are made exactly where and only where the tie dots are.
To do this mod all four big caps have to be removed for you to get access to the traces on the component side. Be very patient as the caps have rigid snap-in type leads that are tightly fitted in the holes, and the pads can be easily damaged. Best to clamp the board on a vise, have a helper ready to pull the cap on your command while you're heating the pins with two soldering irons. If you damage the pads, it's not a big deal as you're hard-wiring them anyways. I damaged pads for one of the caps because I pulled it sooner than joints got hot enough. It's a double-sided board, you want to be sure the far side of a pad gets hot enough too.
Old 14th September 2016, 11:58 AM   #27
Many thanks again, Nattawa. This project turns out to be more challenging and fun than I first expect. I would not have been able to figure out the source of the problem and solution without your help. I will try repositioning the filter cap tonight using your suggestions. I use a small 30VA toroidal transformer.
I just received the Alps RK16 pot and will replace the RK09 too. I hope to finish it before Friday. Precision drilling the holes on the front panel will be challenging.
Old 15th September 2016, 05:04 AM   #28
Solder the cap right next to the transformer ground. The hum is still there, much lower, but still there.
I used an old cap from my tool box. Not sure how good it is and it may have too much leakage. I will try a fresh cap before messing with the ground traces.
Old 15th September 2016, 02:39 PM   #29
phase is offline phase  United States
I put snubber circuits on each supply, where the power enters the board, was an improvement overall. This doesn't probably have any effect on humming/ground problems however.
Another great tip I rceived from a most well qualified source, was to place a 22pf silver mica cap across the the gate to rail of the outputs.
Old 15th September 2016, 03:34 PM   #30
Then, perhaps it does take re-wiring the power supply section to get rid of the hum.
An alternative to having to hack the board could be to build an out-board split rail DC PSU, like the one in the schematic in my last post, to supply the E19 instead of supplying it with the power transformer. Remove the 6,800uF caps and re-use them in the out-board DC PSU, do not leave them on the E19 board.
I don't think the quality of the 470uF cap would be a concern here, by the way.
E19 headphone amplifier board K2381 J407 MOSFET Yuanjing AudioHide this!Advertise here!
All MOSFET Class A headphone amplifier kacernator Pass Labs 4 19th September 2017 02:46 PM
inexpensive YuanJing TDA8920 board from ebay zog666 Class D 52 30th October 2015 11:45 PM
Yuanjing TDA8920B board unstable - 50KHz trevmar Class D 13 28th January 2013 11:36 PM
MOSFET Headphone Amplifier FOXYE Headphone Systems 1 16th January 2013 05:00 PM
Yuanjing? Tripath 2024 board mod potential? Smoken Joe Class D 2 19th November 2009 11:09 PM
