Headphone Systems Everything to do with Headphones
[Help] Headamp design & layout
Old 25th June 2016, 01:41 PM   #1
hta95 is offline hta95
Default [Help] Headamp design & layout
Hi, I'm designing a headamp using opamp + lt1010 buffer chip. The LT1010's quiescent current is roughly 40mA. I have some questions regarding the design and layout
1. Since the lme49600s are obsolete, lt1010 and buf634 are my next contenders. Have anyone had experience with those chip? which one sounds betters in relation with their prices (The buf634 costs twice as much).
2. I have limited experience and knowledge about grounding. I did isolate the signal ground and the power ground and connect them at only one point. Is there any grouding issue or is my layout prone to hum and noise?
Could you pls check the layout and give me some advice.
Thanks!
ha1.zip
Old 26th June 2016, 07:29 PM   #2
OlegSh is offline OlegSh
Not everyone here have Eagle CAD installed to check your layout. Post pics of your design and make your schematic more readable by clearly marking connections of the crossing wires where necessary and avoiding bare wire ends (VS+, VS- and BIAS). Use symbols there.
Oleg
Old 27th June 2016, 03:31 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'd go for the LT1010 as its cheaper and SQ is more an aspect of layout and power supply cleanliness rather than specific chip choices.
Incidentally the quiescent current of the LT1010 is natively only around 6mA, the 'bias' pin in your schematic has a resistor (22R) to raise it.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 27th June 2016, 03:36 AM   #4
rayma is offline rayma  United States
is roughly 40mA. I have some questions regarding the design and layout.
You need a local bypass capacitor, 0.1uF at each IC supply pin.
[Help] Headamp design & layoutHide this!Advertise here!
"My" first design headamp, DC-servo question Mayday Headphone Systems 136 25th January 2016 08:19 AM
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 10:01 PM
FS - Fully populated & working O2 headamp ThuyTN Swap Meet 0 16th January 2013 03:30 AM
headamp design check. Rembrant Chip Amps 7 22nd December 2008 12:14 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 01:49 AM
