Beyerdynamic A1 clone, need some help - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th February 2016, 09:01 PM   #1
Default Beyerdynamic A1 clone, need some help
Hi to all,
I'm kinda new to diy electronics, only made some guitar pedals, so I need your help.
So, I bought this kit:
The Best Byerdynamic A1 Headphone Amplifier DIY Kit 4 Pairs Output Transistor | eBay
and I need some clarifications before I blow something up .
First, the pcb has markings for 2200uF capacitors but the ones included in the kit are 3300uF, what will be the difference?
And second, I have a EI transformer form a halogen lamp, rated at 20VA with about 13,5V output, can it be used to power the circuit?
If it can be used, where do I connect the circuit ground, because it only has 2 output wires.
Thanks in advance.
Old 10th February 2016, 09:44 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Welcome to the forum.
The 3300uF caps will give you more filtering for the power supply, no worries there.
20VA should be plenty for this amp but what does the circuit call for as an input voltage?
Take the Speaker Voltage Test!
Old 10th February 2016, 10:24 PM   #3
Hi, thanks for the reply.
The seller says 13.5V would work, but the recommended is 15V to 18V.
Old 11th February 2016, 10:22 PM   #4
Anyone?
What about the grounding, the transformer does not have one.
Where does the circuit ground go in this situation?
Beyerdynamic A1 clone gold, opamp rolling Dk90 Headphone Systems 6 2nd April 2015 11:24 PM
Beyerdynamic A1 kit smoothlondoner Headphone Systems 0 23rd August 2012 05:39 PM
Beyerdynamic A1 Headphone Amplifier 713708 givethisbookahome Swap Meet 1 14th August 2011 12:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
