Case Layout for Headphone Amp and RPi - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 8th January 2016, 09:22 PM   #1
Bibio is offline Bibio  Scotland
Bibio's Avatar
Default Case Layout for Headphone Amp and RPi
before i go down the workshop and punch out the casework on my friends turret punch can anybody see any potential problems with the layout below?
bottom tray:
Old 9th January 2016, 10:39 AM   #2
arpagon is offline arpagon  Bulgaria
I suppose the two small PCBs are rectifier bridges+capacitors, right?
Why don't you try to put any of them closer to corresponding amplifier PCB?
What is the white area in the upper right corner? Is it reserved for something?
What is the white rectangle between toroidals? Can you try to put there rectifier boards instead?
Old 9th January 2016, 01:37 PM   #3
Bibio's Avatar
upper right is Raspberry Pi.
two small PCB's are regulators, one for RPi and the other is for the USB extension (sort of powered hub).
white area between the trafo's is rectification for the headphone amps.
my only concern is the trafos causing interference. size of tray is w=280mm d=270mm
Old 10th January 2016, 01:00 PM   #4
Jpaul is offline Jpaul  United States
@Bibio, may I ask if you are using a Raspberry Pi i2s dac mounted on the Pi, and placed inside this same case?
Old 10th January 2016, 01:04 PM   #5
Your concerns may be warranted since I'm potentially seeing a big ground loop there, which needless to say, is an invitation for magnetic coupling. Your left and right audio grounds are inevitably going to be joined at both the RPi (with a DAC board, I guess?) and the headphone jack, while being split up on two amplifier boards in between. You will need to interrupt said ground loop somewhere on the amplifier boards, and if it involves just a 10 ohm resistor or so. Other than that, it looks OK - orient the transformer end with the wiring coming out away from the electronics in the final thing.
TBH, going dual mono in a headphone amplifier has zero benefits and a number of drawbacks. It only ever makes any sense for a balanced headphone amp, balanced headphones featuring nicely separated signal returns.
Old 10th January 2016, 02:32 PM   #6
Bibio's Avatar
yes, at the moment i'm using an iqaudio dac+ but i'm thinking of swapping it out for the hifiberry dac+ pro. i remove the phono sockets and wire direct to the headphone boards.
yup i already have a ground loop on my test bed but its a weird one, there is a bad hum until i start to play music at which stage the RPi DAC somehow removes it and will continue until i cold boot the RPI again. upon first turn on of the system there is a HUMMMM then when i start to play music its an inky black silence.
the dual trafos is what Richard recommends for his Sapphire headphone amp.
Old 10th January 2016, 07:08 PM   #7
I see that the dac+ pro has two clocks. I also have some iQaudio dacs, as well as some Audiophonics dacs. The latest audiophonics use saber es9023 with tcxo clocks.
I'll be following your posts on your combination Sapphire/Pi/dac setup.
Very interesting to me.
Old 10th January 2016, 11:04 PM   #8
Bibio's Avatar
i'm a bit slow at doing things so it might take a while.. lol
Old 15th January 2016, 03:05 PM   #9
That probably means that once turned on, the output amplifier of the DAC will remain active, providing a low source impedance. Getting a hum when the output is essentially open circuit is nothing too unexpected and not necessarily an indication of a ground loop, but possibly of insufficient shielding.
Old 15th January 2016, 07:03 PM   #10
Bibio's Avatar
hhhmmm, thats interesting but also disturbing.
i have a dedicated mains line from my consumer unit that powers my audio/multimedia system in my living room. i had this and extra sockets installed when i moved in about 20 years ago and recently i had my consumer unit replaced.
well today i decided that i would try my pifi on another spur in the house (kitchen) and to my surprise when i turned the headphone amp on without the RPi being plugged in i was greeted with silence, not a bit of hum to be heard where before it would hum like a good one. i then turned the RPi on and i now get a buzz instead of a hum so i can put that down to the wall wart that powers my regulator that powers the RPi.
am i happy? hell yes but i'm also disturbed as i now have to track down why i'm getting a bad hum from the mains in my livingroom.
Headphone amp on perfboard: layout critics welcome Preamp Headphone Systems 12 21st April 2014 06:26 PM
Volumio and Rpi DAC tjaekel PC Based 1 5th February 2014 02:34 PM
M3 Headphone Amp with wood/aluminum case with Sigma 11 PSU / Epsilon 12 (DIY AMB) mfspdesigns Vendor's Bazaar 2 16th December 2013 02:07 PM
Class D Audio aluminum case or DIY amp case jtwrace Vendor's Bazaar 3 17th April 2010 02:51 PM
headphone amp in 9V battery case needtubes Headphone Systems 4 15th December 2003 06:05 PM
Copyright 1999-2017 diyAudio
