BUF634 Open Loop with Single Supply - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 2nd November 2015, 02:54 PM   #1
Default BUF634 Open Loop with Single Supply
Can I use a BUF634 with open loop configuration with a Single Supply?
I want to use V+ = 8V and V- = Ground.
Do I have to use a virtual ground at the BUF634 Input ?
Do you know some schematics with the BUF634 using single supply?
Regards.
Alfredo Mendiola
Old 2nd November 2015, 03:11 PM   #2
jan.didden's Avatar
You can use a single supply, but check in the data sheet whether it will work with 8V total supply - IIRC 10V total is minimum for guaranteed performance.
You want to couple the signal to the input via a cap, and use a resistive divider to set the DC at the input to half supply. The output will then also be centered around half supply and you need to capacitively couple it to the load.
I assume you know it is a buffer with gain of 1 x? So 'virtual earth at input' cannot be used as this would set Vin at zero
Jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 2nd November 2015, 03:34 PM   #3
Jan
Yes I don't need Gain, just transform 200 ohm output impedance to 50 ohm impedance.
I Will use virtual ground from an opamp output (Vcc/2) with a 200 ohm resistor to have an input impedance of 200 Ohm. The virtual ground will be connected to the Buf634 input after the decoupling capacitor.
I will use a 50 ohm resistor at the BUF634 output to have an output impedance of 50 Ohm.
Is it Ok?
I don't understand this part:
Regards.
Alfredo Mendiola Loyola
Old 2nd November 2015, 06:02 PM   #4
jan.didden's Avatar
Is it Ok?
Regards.
I think the problem is that you use the term 'virtual ground' in a way I am not familiar with.
Normally 'virtual ground' is a circuit node that is not connected to ground but has zero signal, like the -in terminal of an inverting opamp circuit. So I don't see how a virtual ground can feed a buffer. But you probably use the term in a new unknown way.
Can you post a schematic?
Jan
Old 2nd November 2015, 10:39 PM   #5
agdr is offline agdr  United States
agdr's Avatar
Keep in mind that the BUF634 (and LME49600 for that matter) have a huge output DC offset voltage if not used within the loop of an op-amp. 30-100mV from the datasheet excerpt below. That is likely enough to damage headphones and IEMs over time.
Since you will have to use a resistive divider anyway at the input to set the DC input at Vcc/2 for single supply usage, like Jan Didden said, you might be able to do something really slick here with a DC servo as an alternative to looping with an op-amp. You may be able to replace the bottom (midpoint to ground) resistor of the voltage divider with a transistor set up an a DC servo circuit, or a DC precision op amp (look at the OPA140) set up as the same. That would adjust the BUF634 input to not only be Vcc/2, but also would take that 30-100mV of DC output offset into account. With an OPA140 you should be able to adjust than down to less than 200 microvolts.
The BUF634 will fine on 8V. Its good down to +/-2.25Vdc = 4.5V when used as a single supply.
Old 3rd November 2015, 12:17 AM   #6
agdr's Avatar
Whoops - I forgot that with a single supply you will have a coupling capacitor on the output, so that 30-100mV DC offset of the buffer won't make it out to the real world.
What will be a problem though (specific to these single supply designs) is the leakage current of the output capacitor. It can be substantial during the first minute or so after the DC voltage hits (there is a specification in the data sheet) and the electrolyte barrier forms, enough to make a "pop" in the headphones initially. You can minimize that by trying to find "low leakage" electrolytics at Mouser or Digikey. The pop shouldn't be nearly as damaging to headphones though as the 30-100mV of continuous DC offset out of the buffer would have been. It is a good idea to put some large value minimum load resistor on the amp output (parallel to the headphone), like 2K or so, to allow the output capacitor to charge and the barrier to form even if the headphones are not plugged in.
Here is a schematic I just whipped up, below.
The 20K resistors set the DC voltage at Vcc/2 like Jan said, 4V in this case. They are essentially in parallel as far as the input signal is concerned (the Vcc power rail is effectively an AC short) so that gives you a 10K input impedance. 10K plus the 10uF capacitor gives you an input corner frequency of around 1.5Hz.
The 270R resistor is in there for two reasons. It forms an RF filter with the 620pF capacitor and also reduces the bandwidth to the audio range. If you run this sim with no 270R and 620pF the amplifier corner frequency is around 11MHz - the Buf634 is a wideband part. Amplifying anything above 100Khz or so can only lead to trouble for audio work.
The other purpose of the 270R is short-circuit current limiting. In the datasheet for the 634 they explain that the part has input protection diodes that get forward biased if the output is shorted. That happens for an instant when you plug a TRS headphone plug in the headphone output jack. Here it happens for an instant when that output capacitor is initially a short at power-up. In this circuit it really doesn't matter, but if you had an op amp powering the buf634 input it might.
The 2200uF output cap plus a 32R load gives a matching corner frequency of around 1.5Hz on the output.
In the transient plot note that the input (blue) and output (green) are both centered around zero, thanks to the coupling capacitors on the input and output. But the output of the buf634 itself (red) is centered around that Vcc/2 point, as it should be.
Old 3rd November 2015, 12:50 AM   #7
agdr's Avatar
Default 200R input Z
I just remembered you wanted to translate impedance from 200 ohms. In the schematic above you could use 390R virtual ground resistors, instead of 20K, along with a 560uF input cap instead of 10uF to keep the corner frequency around 1.5Hz.
Old 3rd November 2015, 06:38 AM   #8
With one more capacitor and one more resistor, you can decouple the buffer's input from the power supply. You can easily set the input impedance with the decoupling resistor.
I am curious how well this circuit will work. I recently built a single ended unity gain headphone amp using a BUF634 and a 5532. It is hardly more complicated than your circuit. It definitely sounds better with more voltage; 25 volts seems good.
The single ended LME49600 circuit I built has a voltage gain of 2, and it works great from a 12-15 volt supply; higher voltage does not improve the sound into low impedance, high efficiency headphones, although it is designed to work on a supply as high as 30 volts.
The datasheet circuit along with good decoupling and a good ground layout is all you need.
Old 3rd November 2015, 10:03 AM   #9
jan.didden's Avatar
Not to pick nits but this has nothing to do with cap leakage. At switch-on, the capacitor has to be charged to half supply and that is what causes the plop. This will happen with ANY capacitor here, low leakage, high leakage, film, whatever type.
With a 300 or less load headphone the leakage even at a few 10's of uA will at any rate not be a problem.
Jan
Old 6th November 2015, 04:17 AM   #10
agdr's Avatar
I respectfully disagree.
About this time last year I posted this single supply inverting CMOY project:
Inverting CMOY with inverting DC servo for 5V USB
A fellow had posted a thread asking for help with a CMOY. For fun I split off this thread where I whipped up a board, had it fabricated, built and tested it. Worked great (lol, I even sent one to the op of the first thread for putting up with me hijacking it). The board worked great, except for this same hiccup of leakage current through the output capacitor.
Initiallly in the BOM I had specified an organic solid polymer 470uF 6.3 volt capacitor. I hadn't checked the leakage specs, just built it, and was expecting only a small pop from that intial charging current as you've noted. Intead I had a massive pop that caused me to jerk the headphones off my head. Tracking that one down the leakage current turned out to be the culprit.
Below I've included what turned out to be the leakage specs of that capacitor, vs. the revised low-leakage aluminum electro I went to in the final BOM. The original had 592uA = 0.59mA of leakage, and that's after 2 minutes. During the first minute or so it was likely more in the neighborhood of a couple of mA. The low leakage cap spec was 6uA after 1 minute. So that is a 592/6 = 100 times greater leakage current.
Going to the low leakage cap resulted in a roughly 80% (subjective) reduction in turn-on pop. Nothing else in the circuit changed, just the cap.
In fairness this is a bit of a special case. These organic solid polymer's are turning out to be especially leaky. I believe that opc ran into that a couple of months ago in a thread on one of his "Wire" projects. Someone had noticed an exceptionally high voltage initially in one place and I believe opc tracked that down to this same problem of high leakage in these type of caps.
At any rate, that is my 2 cents, as we say here.
Is there a better way to implement buf634 other than place in a a loop? proid Headphone Systems 2 21st October 2013 11:19 PM
How to plot open-loop gain for single-transistor-input feedback amplifier? steveh49 Solid State 0 14th March 2012 02:59 AM
OPA637 - BUF634 power supply? AudioGeek Solid State 5 21st April 2010 08:14 PM
BUF04 Open Loop Bonsai Solid State 0 7th August 2006 10:09 AM
open loop gain,how many is enough? Leolabs Solid State 28 17th May 2006 09:00 PM
Copyright 1999-2017 diyAudio
