Since the njm4556 are so cheap... class a biasing - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th September 2015, 10:41 PM   #1
00940 is offline 00940  Belgium
Default Since the njm4556 are so cheap... class a biasing
Having some fun with ltspice before having fun with Eagle.
The design goals:
- made for 300R headphones;
- a foolproof amp, thx to an output transformer;
- powered from a single 24V rail;
- relatively inexpensive and using common parts;
- limited heat dissipation/power consumption;
- staying in class a at reasonable output levels.
The biasing scheme's inspiration comes from some of jcx's posts. Each njm4556 is biased at about 8ma.
What do you think ?
Ben.
Old 11th September 2015, 08:57 PM   #2
After some fun in Eagle. The pcb is bigger than needed, but that's to fit it easily in an existing enclosure.
The bottom plane is for a lm317 regulator. The blue plane on top is at v+/2 for biasing.
Ben.
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 07:40 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 05:45 AM
Class A/B Biasing bowdown Solid State 3 23rd September 2004 02:56 AM
Class A biasing of opamps DrewP Solid State 25 24th October 2002 12:18 AM
Copyright ©1999-2017 diyAudio
