Hissing problem of a hybrid amp - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th September 2015, 09:09 AM   #1
Default Hissing problem of a hybrid amp
I have layouted and built an amp according to the Project Ember http://www.mediafire.com/view/6l80ri...schematic_.pdf with some modification: no auto heater selector, using a 24V AC and regulated using LM317 to 30V, added class A bias for the opamp. It sound fine but i got hiss in one channel: IC3 or the opamp on the left of the picture, the hiss change with tube but not the volume level. At first, i used an external LM2596 for the heater and there is no hiss then i install the onboard heater and hiss appeared so i think it must be some layout prolem. Please take a look at my layout and give me some suggestion, i also attached the eagle layout. Thanks!
Old 24th November 2015, 03:39 AM   #2
Why not email Jeremy at Garage1217 directly, he and Franz designed the amp, and they have been very helpful with me .
Old 29th November 2015, 09:49 PM   #3
kct is offline kct  Canada
kct's Avatar
Hi proid,
well, to me it seems that your layout is insufficient in that respect the LM2576 switcher IC is your source of the problem. You should have a good lock at the datasheet for this IC. There are PCB LAYOUT GUIDELINES on Page 8.
It says:
As in any switching regulator, the layout of the printed circuit board is very important. Rapidly switching currents associated with wiring inductance, stray capacitance and parasitic inductance of the printed circuit board traces can generate voltage transients which can generate electromagnetic interferences (EMI) and affect the desired
operation. As indicated in the Figure 15, to minimize inductance and ground loops, the length of the leads
indicated by heavy lines should be kept as short as possible. For best results, single−point grounding (as indicated) or ground plane construction should be used. On the other hand, the PCB area connected to the Pin 2
(emitter of the internal switch) of the LM2576 should be kept to a minimum in order to minimize coupling to sensitive circuitry. Another sensitive part of the circuit is the feedback. It is important to keep the sensitive feedback wiring short. To assure this, physically locate the programming resistors near to the regulator, when using the adjustable version of the LM2576 regulator.
As far as I see, your problem is that:
1.) You seem to have no ground plane on your PCB. In the good old days one got away with two layer boards without dedicated ground layer . Not anymore, newer technology, e.g. switcher demand solid ground plane under its circuitry ! Criss crossing traces without having a solid ground layer in between is a no go these days !
2.) You did not keep the connections as required short, you made them longer than necessary by unfortunate location of some components also some components for the LM2576.
3.) You OpAmp's and associated traces are too close to your switcher circuit. Signal traces have no business to do in proximity to switcher circuit !
The thing with switchers is, they operate at higher frequency, several hundred kHz up to MHz. Generally the switching signal is not sinoid but has sharp edges which contain even higher frequency spectra. Having no ground plane aids the spreading of the 'love' which your OpAmp happily pick up and amplify for you to enjoy.
I suggest to relocate all the components for the switcher to optimize trace length to be much much shorter. Use a solid ground plane under the switcher circuit. No traces that are not part of the switcher circuit shall come in proximity or cross through that area. Use more than just one via for the Diode and capacitor on the switcher circuit ! The instantaneous currents are quite high. Do not use long skinny traces leading to large capacitors, relocate the capacitor closer such that you have short traces.
As a tip, try re-layout the entire board surrendering the bottom layer as a single solid ground layer and put all signal traces on the top layer. Re-arrainge components clever such that they act as 'bridges' over traces so you can accomplish the required connections. In cases where it is not possible, use short wire bridges. SONY used them extensively too.
Unused board space shall be flooded with copper and connected to ground. Use stitching vias to connect top ground flooding with bottom ground, use several vias, one every 10mm.
I hope I could help you out.
SSE hissing problem. mudchute Tubelab 63 13th July 2014 08:08 PM
Mono Amp Hissing Really Bad & Humming/Buzzing TX98Z28 Class D 3 24th June 2014 02:51 AM
static 'hissing' noise problem hakentt Car Audio 20 14th April 2014 07:22 PM
Harman Kardon A-401 Treble Hissing Problem Alarudin Solid State 0 16th January 2014 01:38 PM
lanzar 546-- problem with hissing noise over one channel jmg Car Audio 3 31st January 2008 05:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
