Load output resistors in parallel opamps amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 9th May 2015, 12:08 PM   #1
Default Load output resistors in parallel opamps amplifier
Hi
I have portable headphone amplifier based on this scheme:
http://www.eleccircuit.com/wp-conten...-85mA-size.jpg
only my is:
Master - OPA128SM
4x Slave - OPA627AU biased 5mA to Class A over resistors
How much are minimal safe and stable values for output resistors (R2,R3,R4 on picture)? Original 47ohm resistors I replace with 10ohm and sound is much better. I need low output impedance of headamp too for IEM.
Old 9th May 2015, 04:00 PM   #2
wwenze is offline wwenze  Singapore
Hmm... have you simulated that schematic to make sure it works?
EDIT: Ok, I went to the website on the picture and did a search,
http://www.eleccircuit.com/increase-...-in-85ma-size/
You will build a light meter that uses all four OP-Amps in a LM324 to form a ladder comparator.
But they can provide output current of 20mA only.
So ya, that is a comparator, hence the positive feedback.
For an audio amplifier try this instead
Don't worry about output impedance since the output resistors are in the feedback loop so they don't affect output impedance too much, as long as there is enough power supply and gain headroom (in most audio amps will have lots of).
Minimum value for the resistors is the minimum load the op-amp can drive - imagine a new load current that flows from the output of on op-amp to the output of the other, due to minute differences of output voltage.
That said, there isn't a solid value since op-amps don't suddenly fail when load is too low, but rather the distortion level rises as the load impedance gets smaller. So it's a balance of that versus output impedance.
That said, doesn't matter too much. I would just try a 100 (or 1k since it's OPA627) ohm and calculate the resulting Z-out, if it's below 1ohm I'll forget about further calculations.
Old 10th May 2015, 03:19 PM   #3
Thank You very much for answer and next idea.
Here is really schema of this amp:
e10headamp.jpg at ImageHosting.cz - Hosting pro tvoje fotky a obrazky
Opamps was not biased, biasing is my modification.
I make simulation - with 47ohm output resistors is output impedance about 12,5ohm. Now is output impedance 2,9ohm.
Shunt resistors in parallel to a load? whyvoltage Power Supplies 15 8th January 2014 08:51 PM
LM3886 parallel output resistors jmar Chip Amps 41 2nd May 2013 11:08 AM
Drawing Load Line for Parallel Output Tube blue andry Tubes / Valves 4 4th September 2010 05:58 AM
Changing Output Resistors to Make Current Source Amplifier gni Solid State 2 9th October 2007 04:42 PM
Parallel feed (choke load) in output stage yagoolar Tubes / Valves 27 17th March 2006 10:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
