My O2 & Subbu DAC build - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th April 2015, 03:09 AM   #1
ByronInPortland's Avatar
Default My O2 & Subbu DAC build
Greetings!
I thought I would share my latest completed project. I put the O2 headphone amp and the Subbu DAC V3.0 "Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy together in the same case. Here are some fun features:
  • It can select from analog or digital input via a selector switch on the front panel. This is a 4-pole double throw switch which switches between RCA jacks on the back panel and the analog output of the DAC.
  • It can select line-level or headphone output via another 4-pole, double throw switch, also on the front panel. This switch simply takes the signal from the input switch and sends it to either an other set of RCA jacks or to the O2 headphone amplifier.
  • It has a Twisted Pear TOSLINK module for optical input.TOSLINK Optical Input Module
  • Note that everything on the front panel of the O2 has been replaced with its panel-mount equivalent, and moved to the front panel of my enclosure. This creates quite a tangle of wires crammed into a small space. Hooking everything up was more work than was building either the DAC or the O2. The last image is a PowerPoint file I made to help myself get all the connections right.
  • I'm using a transformer built into the case for the O2 power supply.
  • Also note the inconvenient use of two separate volume control knobs - one for the headphone out and one for the line-level out. I wasn't able to find a good way to attenuate both of these signals with one dial.
  • front panel is from Front Panel Express http://www.frontpanelexpress.com/?gclid=CjwKEAjwsOKpBRCDtfOnzaDg3HsSJAAJ2ojiiZynM--HWgNl2n_2wUc0biIqDAUHEOkZSjXbaDocVhoCdnXw_wcB
I'm very happy with the sound! Thank you, NwAvGuy for creating this project. Anyone feel free to post questions or comments.
-Byron in Portland.
Last edited by ByronInPortland; 24th April 2015 at 03:16 AM. Reason: forgot to add something.
Build thread - building the Subbu DAC V3 SE bcmbob Digital Line Level 1290 18th May 2015 10:51 AM
O2 Amp Build - Resistor Question Clocker97 Headphone Systems 5 18th December 2014 11:46 PM
Subbu DAC & PSU assembled and unused passive420 Swap Meet 4 2nd April 2014 12:21 AM
WTB ES9023 DAC PCB by Subbu & Jean-Paul Reima Swap Meet 5 18th December 2012 07:39 PM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
