Headphone Systems Everything to do with Headphones
Headphone Power Buffer
Old 13th April 2015, 10:47 AM   #11
R.I.P.
ne5534 is not unity gain stable
ne5532 (the dual version) is unity gain stable.
regards Andrew T.
Old 14th April 2015, 06:56 PM   #12
npn is offline npn  Germany
Okay, but paralleling two opamps from such as NE5532 to have more current leads to oscilaling too. D.Self have written it.
Old 14th April 2015, 07:10 PM   #13
udailey is offline udailey  United States
Passive Aggressive
DSelf goes on for a whole chapter if not more on the virtues of paralleling the 5532 and 49710. His conclusion was the more the better. How about the power amp that uses over a dozen paralleled?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 14th April 2015, 07:53 PM   #14
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
NE5532 is unity gain stable; NE5534 is not.
mlloyd1
Old 27th May 2015, 02:37 AM   #15
Einric is offline Einric  United States
Einric's Avatar
Here is my current layout for the dual paralleled NJM4556 headphone buffer with it's power supply.
I was able to have a friend adjust the layout for use of a SIP8 package of the same opamp to gain an additional 200mW dissipation per channel.
AND Mouser has like 5000 of them in stock.
I may do a group buy for the PCB's if the prototype ends up working as planned.
Old 27th May 2015, 04:20 PM   #16
davidsrsb is offline davidsrsb  Malaysia
ADSL drivers like the THS6182 make excellent headphone drivers, while keeping current drain down lower than paralleling "audio" opamps
Old 27th May 2015, 04:25 PM   #17
Einric's Avatar
That chip is $9........
Ouch!
Old 27th May 2015, 06:07 PM   #18
jcx is offline jcx  United States
TPA6120A2DP is cheaper, slightly higher V
and its $5.44 in singles at Digikey
for DSL specs the TPA6120 is the same chip as the THS6012 but its popularity as the TPA6120 audio speced headphone/audio line driver lets us get the cheaper price
I've used the soic 20-wide powerPad package upside down with a cpu cooler clamped to its power pad to run at over 5W per chip
I don't understand the price objection - you would need a dozen 5532 to come close to the output current which is going to take up space, assy time for a objectively worse result given the ancient semi process used
these DSL pretty much need pcb, nice projects spend more on PS, case, pot than all semiconductors together
Old 27th May 2015, 06:20 PM   #19
Einric's Avatar
I'm not running 5532's......I don't know why they were brought up previously......
I am running NJM4556's as a headphone buffer.
I also want everything to be through hole for ease of assembly to any skill level.
Old 28th May 2015, 01:39 PM   #20
The TPA6120A2DP looks good, the more audio focused specs look really good. That supply rejection is excellent, often a problem with opamps
Headphone Power BufferHide this!Advertise here!
Another implementation of Class A buffer for headphone B&W_arthur Headphone Systems 20 5th February 2015 11:32 AM
Inverting headphone buffer class A kacernator Solid State 6 18th January 2013 05:56 PM
Buffer headphone amp percy Headphone Systems 39 11th November 2010 10:14 AM
Headphone amplifier with buffer anbello Headphone Systems 11 1st August 2008 09:59 AM
Buffer/Headphone Amp Dan Banquer Headphone Systems 0 29th August 2003 10:14 AM
