Headphone Systems Everything to do with Headphones
CMoy with other Chips
Old 21st January 2015, 12:05 AM   #1
jhorapalok is offline jhorapalok  Bangladesh
Default CMoy with other Chips
I am new to this field. I like to build a CMoy headphone amp but could not find any OPA (BB) chip in my local market (I am from a sounth Asian country). However, I got NE5532 chip. Can i build a CMoy amp with NE5532? Can anyone kindly give me a schematic to build a CMoy amp with NE5532. I will appreciate any help in this regard. Thank You all.
Old 21st January 2015, 12:22 AM   #2
bimo is offline bimo  Indonesia
bimo's Avatar
Yes, you can. But you should use 600 ohm headphone to get distortion low. If you use headphone impedance below 600 ohm, you can add buffer after NE5532.
Old 21st January 2015, 01:40 AM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I added a simple op amp headphone driver to a mobile disco setup I used to own.
I put a 100R resistor on each channel output so I could drive 8 ohm headphones.
It wasn't deafening but it was loud enough above the disco to be recognisable.
I used the headphones for setting up the next track to play.
If you dont want to add resistors then a high impedance headphone will be required.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 21st January 2015, 01:50 AM   #4
counter culture is offline counter culture  United States
How to Build the CMoy Pocket Amplifier
Now I am Become Death, the Destroyer of Words
Old 21st January 2015, 02:20 AM   #5
sofaspud is offline sofaspud  United States
sofaspud's Avatar
It's the nature of the CMoy design - the less-than-optimal loading of the op amps with low-impedance headphones. That sacrifice in return for simplicity and portability. I say give the 5532 a try. The CMoy is, at its core, a textbook op amp circuit. I don't think the schematic needs to be modified.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 21st January 2015, 02:42 AM   #6
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Or just add as many more NE5532s in parallel (with sharing resistors) until you've got enough drive. Look up Doug Self's poweramp design (for Elektor magazine) using NE5532s - that's good for driving 8ohms. Start with that and delete some of the paralleled opamps according to how low an impedance you need to drive.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 21st January 2015, 08:43 AM   #7
how to add buffer after NE5532?
Old 21st January 2015, 11:00 AM   #8
bimo's Avatar
Something like:
http://tangentsoft.net/audio/pimeta2/misc/sch-2.01.pdf
or
http://hifisonix.com/wordpress/wp-co...-Mini-V2.0.pdf
Old 24th January 2015, 10:59 PM   #9
sgrossklass is offline sgrossklass  Germany
A '5532 should be a good drop-in replacement in a cMoy, actually I would trust its output loading immunity rather more than the original OPA2134's. Maximum current output is about the same.
The amplifier shown here makes use of the JRC NJM4556 opamp, an inexpensive part already designed with headphone use in mind 30 years ago and unsurprisingly still a good performer today - it can basically even do without extra output series resistance, which is not recommended for the '5532. The circuit shown also implements a proper split voltage supply rather than the standard cMoy's rather loose virtual ground (if you use 220 µF buffer capacitors in that one, it's about the equivalent of having 75 µF coupling capacitors on the output).
Old 25th January 2015, 07:27 PM   #10
Thank you so much for your comment. As i said, i am a beginner in this field and i have NE5532 chip in my drawer not any OPA chip. Will you please show me a schematic that i can follow blindly with 5532 chip. I am very eager to make a good sounding headphone amp. In my local market there is no OPA chip. Thank you once again.
CMoy with other ChipsHide this!Advertise here!
Cmoy help please! goocher89 Headphone Systems 20 2nd August 2014 08:28 AM
µCmoy - My take on the portable CMoy amp The Coolest Headphone Systems 10 30th July 2014 09:53 PM
New CMOY Hewie Chip Amps 6 21st March 2011 10:52 AM
Chips for Chumps aka "Intelligent Chips" jackinnj Solid State 0 15th April 2005 12:37 AM
CMOY Help? sbelyo Chip Amps 2 3rd July 2004 10:14 AM
Copyright ©1999-2017 diyAudio
