Converting the Bugle2 to a headphone amp? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 6th January 2015, 10:15 PM   #1
mtflycaster's Avatar
Default Converting the Bugle2 to a headphone amp?
I'm a bit new at this, but for DIY fun and a learning exercise, I'm building a 12-0-12 regulated voltage supply for my Bugel2. Will put the PSU and the Bugle2 in separate metal boxes, and ground the boxes. Then, was planning on simply deleting the Bugle2's TLE2426 voltage divider, and leave all else the same. Gets rid of the virtual ground.
First, and notwithstanding the fact that the new Bugle2 boxes may or may not actually sound any better, do you guys who are much smarter than me on this stuff see any issues with this?
And if this will basically work, now that the current limited TLE2426 is out of the way, could not this approach be used to make a Bugle2 based headphone amp? Maybe need different, higher current opamps? Or is this just overkill?
I know I could build an great O2 amp for much less, but that's not the point of this for me.
I'm curious to see how well it might work and sound. And I could always go back to using the Bugel2 just as intended!
Thanks!
Old 7th January 2015, 11:49 AM   #2
While a linear, "real" split supply certainly seems more trustworthy than a SMPS with rail splitter in a low-noise circuit (though the Bugle 2 seems to have fairly extensive filtering), be careful not to open a can of worms there. Your well-meaning grounding, for example, may well complete a ground loop depending on what else is in the setup.
Conversion to a headphone amp makes little sense to me - you'd lose most everything that makes the circuit special (input impedance matching, RIAA EQ).
Old 7th January 2015, 01:17 PM   #3
Banned
I'd have to agree with sgrossklass, conversion to a headphone amp doesn't make sense to me neither.
Old 7th January 2015, 11:50 PM   #4
Thanks, gentlemen. That's the feedback I'm looking for!
Going to build an O2.
converting car speaker wires to headphone jack PantSeatFlyer Car Audio 20 12th August 2016 01:01 AM
Bugle2 or Boozhound JFET? bunkhokum Analogue Source 6 11th July 2014 12:25 AM
Bugle2 with Burson Dual Op Amps httime1 Analogue Source 9 9th November 2013 02:52 PM
Integrating Bugle2 PSU into preamp design (also Aikido 12VAC and Gainclone) Sodacose Analogue Source 5 27th August 2013 03:08 AM
converting a dynaco mark IV driver board for headphone amp use speakerfritz Tubes / Valves 0 27th November 2010 07:51 PM
Copyright 1999-2017 diyAudio
