Headphone Systems Everything to do with Headphones
Headphone amp schematic
Old 3rd February 2004, 08:43 PM   #11
kmt is offline kmt  Germany
Thank You for Your reply!
This is a good question; I read the datasheet of the BUF 634 and there was a schematic for a headphone amp using a pre stage. I guess they use a pre stage to implement a feedback loop, because the 634 doesn't have a negative input. As a second point, I have the possibility to adjust gain for the driver. This could be helpful because I don't know yet the signal level present at the input of the amp.
Greetz
KMT
Old 4th February 2004, 08:33 AM   #12
bjornagain is offline bjornagain  Sweden
Most applications for headphones have a gain around 5, which is hard to get with a buffer :-). My recommendation is to keep the number of stages to a minimum if you want good sound. In your case one stage is enough if you let it have a gain of 5 instead of unity. The 5532 can drive a pair of modern headphones directly.
Some speedier op's (which you can try) is not internally compensted for unity gains either. Having a gain of 5 gives you freedom. Don't solder the op, put in a holder so you can replace it and try different ones!
If you have a sufficent output from the source just go with the buffer witout any preceeding op:s.
Best regards,
Bjorn
Old 4th February 2004, 09:11 AM   #13
Look at datasheet for BUF634 page 10.
Then try it with AD797...
Please report here ;-)
Best regards,
Bjorn
Headphone amp schematicHide this!Advertise here!
Headphone out schematic US2400 Headphone Systems 5 27th February 2009 01:21 PM
Solid State HeadPhone Schematic mod_evil Headphone Systems 0 12th April 2005 02:41 AM
Looking for Schematic Perreaux SXH1 Headphone Amp. Franklin Headphone Systems 0 23rd December 2004 06:16 AM
Request peranders qrv02 headphone amp schematic 5th element Headphone Systems 1 26th July 2004 11:51 AM
Headphone Amp d-audi Headphone Systems 13 22nd October 2002 06:41 PM
