One Ohm Resistor Separating Grounds? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 17th October 2014, 02:11 AM   #1
ammel68 is offline ammel68  United States
Default One Ohm Resistor Separating Grounds?
I recently purchased a headphone amp PCB which uses two OPA2134's and a TPA6120.
The audio input ground is connected to the power supply ground through a 1 ohm resistor.
Only the feedback resistors for the 2134's and the 6120 are connected to the audio input ground.
All other components including the headphone output, are connected to the ground plane connected to the power supply ground.
Can someone explain what the theory is behind this?
Thanks...
Old 17th October 2014, 02:27 AM   #2
DUG is offline DUG  Canada
Ground loops...where some of the higher current traveling in the ground path affects a small signal that has the same common ground path.
Much theory and debate as to the best way to minimize this problem.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 17th October 2014, 03:44 AM   #3
Does the 1 ohm resistor, connecting both grounds, prevent ground loops somehow?
Old 17th October 2014, 04:08 AM   #4
Reduces.
220 Mega Ohm Resistor - Really DrummerChick Tubes / Valves 22 22nd June 2013 12:33 PM
Riken Ohm Resistor Stash For Sale aethertransit Vendor's Bazaar 0 28th March 2013 10:00 AM
Replacement for 200 Ohm variable resistor? maurycy Parts 5 8th April 2012 01:22 AM
Effect of adding 4 ohm resistor to tweeter uzernaam Planars & Exotics 19 6th November 2010 01:08 AM
power resistor value ohm an watts?? panduro Power Supplies 13 22nd July 2010 07:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
