High-voltage hybrid headphone amp - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th September 2014, 03:08 PM   #1
janim is offline janim  Slovenia
Default High-voltage hybrid headphone amp
Hy to all!
As my first DIY audio project I decided to create a headphone amp. I found lots of info about power supplies and first (gain) stages. But I can't find any info on how to design an output stage. So I find myself with a 250V power supply (we don't want to let the tube hungry ) an IRF820 acting as a cathode follower (also doesn't complain) and no idea how to continue.
I tried something like this only with mosfet replacing the V2. It works, but there is no gain - with P1 on max the only amplified thing is the noise.
Soo... What do you think? I'll be very thankful for any help...
Old 11th October 2014, 11:28 AM   #2
So I was looking for more info on the web. The main reason why I went with a mosfet cathode follower was because of this site: mosfet follies. But I see now that it won't be so easy. So I have several option:
- I can stick to the original schematic and buy some tubes
- I can modify a similar design I found on this forum (Hybrid tube headphone amp design) to work on 250V
- or add a 12V source to power a Seekers amp as shown on this project: link.
So what do you think? Any pros/cons with this designs?
And before you say it: Yes, it is tubes for tubes sake But I'm having so much fun!
Old 11th October 2014, 05:17 PM   #3
Stixx is offline Stixx  Germany
I am
Stixx's Avatar
Have a good read around here --> Cavalli Audio
Even Mr. Cavalli hasn't succeeded in buidling a high voltage hybrid (the "Stacker"),
so abandon the plan or change your design to use low voltage tubes.
www.original-ton.net
Old 11th October 2014, 05:17 PM   #4
00940 is online now 00940  Belgium
For high impedances headphones, I'm very happy with this: -follower hybrid headphones amplifier
It kind of fits your goals.
Ben.
Old 12th October 2014, 01:43 PM   #5
It does actually. I have read about the mu-follower amp HERE, and it mentioned also low impedance outputs (well, actually with srpp design, but it's very similar). I never found a complete schematic that's been tested though. I'll check it out. Thanks!
Old 12th October 2014, 04:05 PM   #6
It seems that if you are willing to employ AC coupling and voltage clamps to protect the solid state devices, you could configure anything you want. You could even apply AC coupled global feedback for any popular configuration.
I know that a lot of you guys hate coupling caps, but properly applied they do not present a big challenge. Ad-hoc selection of low frequency poles can result in greatly inferior bass response; this much is true. But the trick is to make the input pole dominant, and separate the rest of the poles as best you can. The most important aspect is to have as large a gap as possible between the input pole and the feedback pole. If you can "bury" the feedback pole, then distortion from the feedback capacitor becomes a non issue.
I recently built a single ended, AC coupled headphone amp employing the TI 49600 buffer. Its dominant low frequency pole is 2.7 Hz. It has slow start (real slow; 2 second startup) and diode clamps on all the big audio caps to mitigate start up thump and eliminate shutoff noise and potential latch up at shutoff. It runs off of 12-30 volts DC. It is completely fool proof and convenient to use. From a practical point of view it leaves nothing on the table; it is super clear, provides more clean power than you should ever use, drives 32 ohm headphones super loud and clear with a 12 volt supply, and theoretically should provide ample power for high impedance headphones with a 30 volt supply. I don't see why a tube front end and a high voltage discrete solid state buffer couldn't be configured using these same principles, but then I have never tried either.
FS: Original Millett Hybrid Low-Voltage Headphone Amplifier craigtone Swap Meet 3 5th January 2013 02:46 PM
HPA-2 Headphone Amp Kit (High quality & High-end components) kawo Group Buys 20 17th February 2012 04:34 PM
RTB11 mini hybrid low voltage hifi headphone amplifier siliconray Siliconray Online Electronics Store 3 17th October 2011 03:41 PM
Opinions on my low-voltage hybrid headphone amp (this time with the right file) JHawk24821 Headphone Systems 2 1st August 2004 04:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
