Best way to implement a voltage gain stage with opamp? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 19th August 2014, 01:35 AM   #1
Default Best way to implement a voltage gain stage with opamp?
I was wondering is there anyway to make an opamp sound better than the non-inverting configuration? When talking about opamp, i see most of the configuration both diy and commercial end up with just several resistor in non-inverting mode. Is that the best way to implement an opamp?
Old 19th August 2014, 03:41 AM   #2
Is there anyway better than non-inverting mode ?
-----Can you post more detile information about non-inverting mode?
Old 19th August 2014, 03:43 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
In my experience opamps sound better the more attention that's paid to the power supply.
No matter if we meanwhile surrender every value for which we stand, we must strive to cajole the majority into imagining itself on our side - Everett Dean Martin
Old 19th August 2014, 04:36 AM   #4
Non inverting mode like a cmoy
Of course an amp will sound better with better power supply, but i'm asking about how to implement an opamp.
Old 19th August 2014, 06:38 AM   #5
Mooly's Avatar
Make sure the opamp isn't on the verge of instability. Squarewave test the circuit and apply compensation if required. Add an RF input filter. Consider trying minor manipulation of the "noise gain" to reduce the open loop gain of the opamp.
A Different Opamp Compensation Technique.
Installing and using LTspice. From beginner to advanced.
Old 19th August 2014, 09:20 AM   #6
Thanks Mooly, your thread is so interesting but i wonder if i use inverting configuration, do i need to use at least 2 opamp to get the output signal back to it original polarity?
Old 19th August 2014, 09:43 AM   #7
Mooly's Avatar
You can apply the same technique to the non inverting configuration. R3 in this diagram.
Old 20th August 2014, 07:01 AM   #8
Thanks, i will try this.
Old 20th August 2014, 07:06 AM   #9
Mooly's Avatar
OK. Its well worth trying.
Old 20th August 2014, 03:00 PM   #10
jcx is online now jcx  United States
bad example Mooly - I don't think so - not with that chip, those high R values
proper op amp selection and the standard circuit are fine until you want better than -100 dB distortions with high source Z
you need to decide if that is your "problem" now or not? - don't let futile search for "best" when you don't yet even understand the dimensions of the problem get in the way of moving forward with proven circuits
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
Voltage gain stage for Non-NFB MOSFET current amp gripracer Solid State 50 23rd October 2009 02:37 AM
What about FETs for Cellular Base Stations in Audio Cascode Voltage Gain Stage (line tiefbassuebertr Solid State 8 23rd August 2009 02:53 AM
+/-15Vout opamp for gain stage anli Solid State 14 10th December 2004 11:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
