Stereo crosstalk gets worse with frequency? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 22nd May 2014, 02:55 AM   #1
Post Stereo crosstalk gets worse with frequency?
Hi, Guys
I'm debugging on my TPA6120 board and tested its RMAA with E-MU 1212M. For now, the results look ok except stereo crosstalk:
-90db is not so good, so I looked into the detailed graph:
While the frequency goes higher, the stereo crosstalk gets worse?...
My question is quite straightforward then:
Why could this happen?
And how to solve this problem?
Old 22nd May 2014, 04:02 AM   #2
jcx is offline jcx  United States
its not a audible problem - crosstalk is one of many numbers that quit correlating with hearing at gross levels by what electronics achieve
anything better than ~40 dB is fine as long as it is linear, not too strongly peaking in frequency
the chip is capable of better by the data sheet - so you may have compromises in the board, gnd layout or are just seeing TRS common impedance and cable wire mutual coupling - at -60 dB debugging your test setup is critical too
Old 22nd May 2014, 04:55 AM   #3
Presumably either capacitive or inductive crosstalk between the channels, or both. Like jcx already wrote, if you want to improve it, check for common wires or wires of one channel that are close to wires of the other channel. High impedance nodes are particularly sensitive to capacitive crosstalk, low impedance loops to inductive crosstalk.
Crosstalk? Do It Yourself Analog Line Level 2 17th August 2013 10:26 AM
Crosstalk and image. Mooly Solid State 4 8th December 2009 06:25 AM
2 channels to 1 crosstalk dreamtear Parts 1 19th January 2008 01:42 AM
Stereo to binaural and crosstalk cancellation Nixie Digital Source 0 8th February 2006 12:34 PM
Stereo speaker crosstalk cancellation I_Forgot Digital Source 1 15th February 2005 11:49 PM
Copyright 1999-2017 diyAudio
