o2 flush gain switch? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 13th May 2014, 08:41 PM   #1
Default o2 flush gain switch?
Not sure if this is the correct place to ask this, but here goes.
I want to replace the gain switch on my O2 amp for one that is approx flush with the faceplate or even recessed.
Is it possible?
Would any of the more experienced than me, be able to suggest a suitable replacement part?
I do believe it is a sensible mod, considering how infrequently most will need the extra gain and the pain involved when you don't realise your kid has been pushing buttons.
Old 14th May 2014, 02:26 AM   #2
agdr is offline agdr  United States
agdr's Avatar
The gain switch has a notch around the shaft. You could snip the shaft there with some flush cutters. The button wouldn't fit on the shaft anymore, but the shaft would be flush with the front when out. You could use the point of a pen to push it in and out. If you are using one of the standard drilled panels though the hole around the shaft would still be sized for the button - pretty large. Maybe a circle of tape could be placed over the hole, with a small hole in the center just big enough for a pen point.
Old 14th May 2014, 08:05 AM   #3
That would work, thank you
O2 headamp PM latch PC board to stop O2 low battery buzzing agdr Headphone Systems 0 24th April 2014 01:20 AM
Switch mode between Hawksford error correction and NFB by Unity Gain tiefbassuebertr Solid State 4 5th October 2009 07:46 PM
need help: clean gain switch Alan Ang Car Audio 1 23rd November 2007 10:05 AM
effects of gain selector switch in the feedback loop? scone Chip Amps 13 4th March 2005 07:22 PM
Gain Clone Entry Module? Corcom fuseable with switch. KevinLee Swap Meet 0 24th April 2003 03:34 AM
Copyright 1999-2017 diyAudio
