Headphone Systems Everything to do with Headphones
Headphone amp on perfboard: layout critics welcome
Old 15th April 2014, 11:27 AM   #1
Preamp is offline Preamp  Germany
Preamp's Avatar
Default Headphone amp on perfboard: layout critics welcome
Since I'm having a hard time getting any layout done for months and years, I suddenly changed my mind to go with perfboard. I've got some lying around and this way I can simply get going with it and finally build something!
So I sat down yesterday and created a 100mil-spaced layout. I wanted it to be rater space-efficient and not widely spread over a giant, mostly empty board. I also didn't want to have much wire links in there, so I decided to leave the power supply lines unrouted till the end and finally wire them directly to the PSU.
Trying to obey the rules of proper grounding, I ended up with a power ground (dark blue trace) and a signal ground (light blue trace). Please have a look at the attached picture. The red square is the point that connects directly to PSU ground. I'm not sure however whether I can safely connect both grounds together on-board in the area encircled in red or if it's mandatory to run a second wire to the PSU from the red X.
Probably it's best to ultimately test it out, but I'd still like to hear some suggestions beforehand. Do you think that my overall thoughts are OK so far or did I even do something terribly wrong?
In case you might wonder: the output transistors are supposed to be mounted to the case, lying flat beneath the board.
Any comments are greatly appreciated .
Old 15th April 2014, 07:43 PM   #2
Preamp's Avatar
Here's the schematic.
Old 16th April 2014, 02:17 AM   #3
agdr is offline agdr  United States
agdr's Avatar
Just off the cuff... you might be offending the symmetry gods here. I would be expecting a LED, or two 1N4148s in series, on either side of the feed. One going to each transistor base. It should work but the IC4B op amp output would settle at a Vbe drop off center. I'm no discrete wizard though, better get some more opinions.
Old 16th April 2014, 08:07 AM   #4
Preamp's Avatar
Not sure whether it's correct, but this is supposed to be the schematic of a well-known commercial amplifier .
Wouldn't that mean that IC4B is effectively working in Class A?
Old 16th April 2014, 11:52 AM   #5
jcx is offline jcx  United States
the op amp output isn't reliably biased Class A with symmetric opposed CCS of the same value
I wouldn't use both CCS
the schematic is pretty generic - could be expected to find similar circuits 30 years ago
some in audio do make a fetish of brand or design by a "big name" - but audio design, EE is much deeper in history than most impressed by the audio ad copy may appreciate
but of course the 1st question hasn't been addressed - what headphone(s) - they vary way more than loudspeakers in I,V, power required - to the point that some amps are really bad matches to some headphones
Old 16th April 2014, 11:59 AM   #6
Preamp's Avatar
I'm going to use it with my DT-990 250Ohm or maybe even the DT-770 80 Ohm.
Since the amp is from Beyerdynamics (or beyerDIYnamics in this case ), I suppose them to play quite nicely together.
Old 16th April 2014, 12:26 PM   #7
for those headphones you can just use small signal Q, don't really need the BD139/140 - 20 mA will drive the 770 80 Ohms to 120 dB SPL
for deep Class A output stage even t0-92 would work if you drop your supply V by 1/2 - the 880 250 Ohm only needs 2.8 V to reach 120 dB SPL
I also don't know where you're going with all the inverting, the inverting input low Z input makes it poor match to a volume pot
the "always invert" recommendation really only applies when you try to get to single digit ppm distortion levels - and you won't with those op amps
Old 16th April 2014, 04:34 PM   #8
Preamp's Avatar
Well, thanks for your comments.
Guess I'll now be looking for another design and still won't start building anything soon...
Old 16th April 2014, 05:32 PM   #9
with perfboard you aren't committed - can easily add, undo, incrementally increase complexity
Designing An Opamp Headphone Amplifier | HeadWize shows some options for op amps, buffers
even just a resistor pull down single emitter follower op amp buffer with ~30mA would get you started if you use R, Q that can handle 1-2 W
Old 16th April 2014, 05:56 PM   #10
Preamp's Avatar
Sure, but this time my plan was to start out with a known (good?) design and not go through all that trial-and-error. Well, but now I'm getting rather intrigued - that's what makes diy audio a great hobby after all, isn't it?
Headphone amp on perfboard: layout critics welcomeHide this!Advertise here!
Rod Elliot P3A Layout - Critics paranoid06 Solid State 389 10th April 2018 11:46 PM
MeasureExplorer: perfboard vendor anechoic Parts 0 18th July 2007 11:19 PM
Should I try again on PCB's or go for perfboard? Spasticteapot Chip Amps 14 29th June 2006 04:48 PM
What type of Perfboard? riotubes Parts 3 23rd July 2005 06:27 PM
Critics needed kimschips Solid State 29 26th March 2005 02:49 PM
