Low cost Stax headphone amplifier - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 18th April 2014, 01:36 PM   #11
Dear Calvin and Jaclement,
Thanks for the suggestions.
Originally Posted by Calvin View Post
the excellent ITH 02N250 in TO247
Oh yes it is available.
Sadly its a little expensive, more than the price of a triode!
So I have taken some inspiration form the circuits Calvin included and the good success Jaclement had with such a simple design.
I shall build a few, ideas and see how they all work. I have ordered a nice high voltage transformer and some high voltage capacitors.
I also ordered the "6SN7GT B" for a comparison as I think I will build a MOSFET and a valve based design and see which I like best.
I particularly like the idea of modding the opamp driven MOSFET with no output capacitor, as I have read (but don't know if it's true yet), that at such high voltages the capacitors "sing", maybe with a DC servo to set the voltage right.
Can I just use the "ITH 02N250" in place of the output MOSFET's in all of the designs Calvin posted or would I need to make many changes to bias?
Best regards
Owen
Old 18th April 2014, 01:57 PM   #12
jcx is offline jcx  United States
even film caps can become "piezoelectric" when they have high DC bias (polarization dependent electrostriction)
but this depends on the construction - the plates have to be able to move - used to be a problem in old oscilloscope ps with audio frequency chopper supplies and oval Mylar caps - the oval shape doesn't allow for even winding pressure, worse some were wound on removable round mandrels and then squashed to oval shape
high tension wound, or bonded layers will have much less problem
the really paranoid could stack+parallel a few of the biggest, highest V rated NP0/C0G ceramic caps - a solid, void free, nonpiezo material - at considerable cost
but the concern in electrostat amp output DC blocking is probably overstated - you also need high AC too and its usually the case that you are using 100x the expected ES headphone Cload so the output caps only see 1% of the audio AC
Old 15th November 2015, 12:39 PM   #13
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by owenhamburg View Post
Dear all,
I have a pair of Stax Lambda Pro Bias headphones, and two SRD 4 electret transformer drive units to which I have added a pro bias supply using some fiddly soldering. I am not 100% happy as the bass is poor and I currently have 2 boxes with wires joining them to supply my headphones. I suspect the bass issue is that I am being limited by the performance of the transformers and not the headphones.
Owen
Nice schematic, have similar going in my head for a while. I Like that idea about bunch of twin triode LTP“s with ccs in cathodes.
On input side a Lundahl input trafo, wired as centertap for max symmetry. And endstage maybe ecc99 or bigger triodes, working into centertap choke.
Supply plus side grounded. Stators wired to choke ends. Lundahls interstages cost like plate chokes..so you can use that instead
Not a problem, since input trafos have 1500v insulation.
Plate choke will improve distortion-linearity, better than resistor. Not cheap tho
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 STAX SR007 # LL2748 > 394A > LCLC 4H/100µ
Stax SRM-3 headphone amplifier dziemian Swap Meet 6 6th February 2014 10:40 AM
Low cost class A Hi-Fi amplifier 807 S.E. Ultralinear - Pentode drivers [6G6G] pilovis Tubes / Valves 4 31st August 2013 05:03 PM
SenseV1-cost effective hifi VMOSFET headphone amplifier siliconray Siliconray Online Electronics Store 2 7th July 2012 01:26 AM
DIY Max Power Low Cost Amplifier Design simon7000 Solid State 48 23rd May 2012 09:55 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 14th September 2010 12:39 AM
Copyright ©1999-2017 diyAudio
