3,5 to RCA cable - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd March 2014, 08:25 PM   #1
Default 3,5 to RCA cable
Hello!
I am want to make 3.5 to RCA cable from two-core wire with braided shield wire around it. My plan is to feed signal from UCA 202 to O2 amp.
Question 1
Do I realy need shield wire, will it give me any audible effect?
Question 2
If the answer for my first question is yes, than what is the proper connection between RCA , 3.5 jack and braided shield wire?
Should I connect braided wire with 3.5 jack and with RCA plug?
Thank you!
Old 23rd March 2014, 08:39 PM   #2
Is your 3.5 plug/socket, a stereo or a mono?
regards Andrew T.
Old 23rd March 2014, 08:50 PM   #3
It is stereo.
Old 23rd March 2014, 08:56 PM   #4
you need a ground and two signal wires as a minimum.
This could be done with a two core (not twisted) and a shield.
But better would be two twisted pairs, with or without a shield/screen.
Each twisted pair will feed one RCA/Phono.
regards Andrew T.
Old 23rd March 2014, 09:12 PM   #5
Can I ground screen and one core wire to RCA plugs and ground screen to 3.5 stereo jack too?
Old 24th March 2014, 11:54 AM   #6
You need two RCA/phono plugs for stereo.
You need a Signal Flow and a Signal Return for EACH RCA/Phono plug.
regards Andrew T.
Old 28th March 2014, 10:42 AM   #7
I've been more and more buying into the idea that coaxial cables are the Right Choice(TM) for RCA interconnects (i.e. unbalanced circuits). With two signal wires plus a shield, you always have the dilemma of what to do with the shield - do you want to hook it up to the ground on one end? This has its disadvantages according to some cable makers (notably a budget cable company going by the name of a popular type of denim trousers) in that it raises the total capacitance of the cable.
Long story short, you need per channel a signal wire in the middle with a shield/ground around it.
Something like this:
... to varying amounts of fanciness. Or two lengths of thin coax cable, with various ways of creating a Y-split. A bit of heatshrink and twisting is all it takes, techflex if you're trying to be fancy. Try to find the lowest capacitance cable you can find where both channels will fit into the 3.5mm plug. Canare makes a really solid one with a pretty fat cable entrance.
diy rca cable with Vagus 3way teflon insulated cable umut1001 Parts 5 29th August 2012 02:00 PM
component video cable? same as RCA? gychang Parts 5 15th January 2008 12:59 PM
S-video to RCA cable? coolpoppa Everything Else 6 26th September 2006 01:44 PM
TRS to RCA cable turn_on_air Everything Else 1 25th July 2004 09:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
